I'm running PE6 using the #slot and trying to write to data memory using the 2 attached programs. Programs load & run okay. Only thing is I can't seem to write to the data memory using #slot. Each program will write to the data memory if I comment out line 28 & run the program using the simulator; I can see the data being written in the data memory panel (must comment out the "run" command since it's not supported in PE6 yet). Any ideas about what's going-on?
Thank you, JimsView attachment test #slot 0.basView attachment test #slot 1.bas
