Hi Folks.
Over the past years my eyes have been getting worse, and I get tired of needing several sets of glasses around so I can do work.
I investigated the cost of a decent microscope for work and the price was pretty horrific.. So I made my own for under $85
Parts - 7cm Car Reverser LCD monitor for about $30, TV Microscope for about $40, Microscope Stand TE13 $12, and a plate of some heavy material.
I found that the monitor actually ran internally on 5v so i did not need to use an extra power supply, but if you cut off the LCD's lead you MUST put the unused video line (it has 2) to ground.
The end results is this
You can easily get tools etc under it to work on boards, At 10cm between work area and scope it give you about x10 magnification, the closer you go the higher the magnification.
I am using a video camera without the lens as my example and I have no problem with seeing the feeder wires on the actual CCD. Closer levels can get up to about 300+ magnification.
As you are looking in the direction of your work it;s easier to co-ordinate rather than having to look at a laptop/desktop with a USB Scope.
Enjoy
Marc
Enjoy
Marc
