Controlling LED with microcontroller 28x2 through AXE132 LED driver kit
Hello,
I can't get microcontroller 28x2 http://www.picaxe.com/docs/axe401.pdf to work with Serial LED 16x2 Display WC1602A http://www.wincomlcd.com/pdf/WC1602A-SFYLYHTC06.pdf through AXE132 OLED/LED driver kit http://www.picaxe.com/docs/axe133.pdf. The main problem is that i don't know if i am using right output pin from 28x2 microcontroller. I have tried both C.6 and C.7. I also checked if these components are powered correctly. If i have forgotten to mention something you need to help me with my problem, please tell me and i will answer ASAP.
Thanks all for help.
Welcome to the PICAXE Forum.
The AXE132 firmware can put up a 'welcome display' which allows the AXE132 board and LCD display to be be tested without having to drive it from another PICAXE.
Make sure you have downloaded the AXE133 serial firmware into the 18M2 on the AXE132 board. Any serial control has to be from a PICAXE which then connects to the AXE132 board running the AXE133 firmware.
Thank you for response.
I have downloaded firmware as you mentioned. Should the LCD do something now? Like display welcome message?
After that i connected AXE 132 to 28x2 controllers power source(5V). Downloaded this program to 28x2:
init: pause 500 ; wait for display to initialise
main: serout B.7,N2400,(254,128) ; move to start of first line
serout B.7,N2400,(“Hello!123”) ; output text
end
Still nothing shows up on display. I feel like i miss something important and i can't figure that out. Thank you for time.
bfgstew
Have you done this part?
If so what pin of the 28X2 are you using to send data to the LCD? You mentioned in first post that you used C.7 and C.6, now you trying to send data via B.7? Make you have the correct pin in the serout command.
bfgstew
Have you adjusted the contrast on the LCD?
Have you got 5v at the LCD?
Is there any change when you power up?
What code have you used and to what chip have you downloaded it to?
Also you need to post a proper clear picture of your set up, showing both sides so members can see if there are any mistakes.
nick12ab
Have you connected the display to the AXE133 PCB properly? Your LCD display has the two backlight pins at the opposite end to those on the LCD modules Rev-Ed use otherwise the pins are in the same order.
For your LCD module you must not line up all 16 pins with those on the AXE133. Can you provide a photo of how you have put them together?
I see what you meant. I had it connected badly. Now i am trying to figure out which pin on AXE132 at H1 header should be connected to which pin on my LCD module.
Again, i have this kind of LCD http://www.wincomlcd.com/pdf/WC1602A-SFYLYHTC06.pdf. Which is different from those on PICAXE e-shop. If someone is aware where to find which pin from header H1 is connected to which pin at LCD which is sold on PICAXE e-shop, maybe i would be able to connect it through wires as it should be.
I hope i made myself clear and everybody understood.
Thank you. I have connected it to as you said. I found another issues ( bad luck whole day ).
First is that the right pin(in your image) for backlight is not connected to V+, which should be connected to pin 15(V+) on LCD.
Instead of it i used Vdd(5V) to power LEDs in display. When i adjusted contrast (on preset 10k resistor) of LCD it showed some vertical and horizontal lines (there should have been "Hello!123" text). I also noticed that these lines started to very slowly dissapear.
This is how i connected it:
The second one is more detailed view on AXE132 and LCD connection.
I still use this script from 28x2:
serout B.7,N2400,("Hello!123") ; output text
end
And i still use this downloaded script from picaxe web for AXE133:http://www.picaxe.com/downloads/axe133.bas.txt
bfgstew
Try this, as the command (254,1) initalizes the LCD!
init:
serout B.7,N2400,(254,1)
pause 50 ; wait for display to initialise
pause 50
end
I will try that out and post if it worked asap.
I was thinking about checking out if the firmware is correctly downloaded to 18m2 chip, is there a way how to download FROM 18m2 TO picaxe software?
Thank you!
bfgstew
; v2 18/01/2012
#picaxe 18M2
; Note you must uncomment just one of these two options
; depending on whether you have an LCD or OLED module
;#define use_OLED
[COLOR="#FF0000"];#define use_LCD[/COLOR]; ********************************************
; Supported Commands
; 0-7, 8-15	CGRAM characters
; 16-252	normal ASCII characters, according to selected character map table
; 253, X	display 16 character pre-saved message from EEPROM memory, X can be 0-15
; 254, X	LCD command, X can be 0 to 255
; 255, X	control outputs C.2, C.1, C.0 (via lower 3 bits of X)
;		So, if using a backlit LCD with the active low transistor driver
;		on output C.2, then 255,%000 switches backlight on and 255,%100 switches off
#define use_welcome	; display the welcome message upon power up
symbol line_length = 16	; change to 20 for displays with 20 character lines
symbol baud = N2400_16	; Serial baud rate 2400,N,8,1. Note main program runs at 16MHz
symbol spare0 	= C.0 ; spare output 0
symbol spare1 	= C.1 ; spare output 1
symbol spare2 	= C.2 ; spare output 2 (or optional backlight)
symbol backlight 	= C.2 ; optional backlight control for backlit LCDs, active low
symbol RX		= C.5	; serial receive pin
symbol enable 	= C.6	; LCD enable
symbol rs 		= C.7	; LCD RS
; LCD data pins are on B.0 to B.7
; Store the 16 character user defined messages in EEPROM data memory
; First two messages are optionally used as welcome message
; If using a display with 20 characters you will need to edit
; the start addresses to be multiples of 20 (currently at 16)
; and add 4 characters to each message.
; Please remember 4 line displays always use the strange 1-3-2-4 layout.
#ifdef use_OLED
EEPROM $00, ("  Serial OLED   ") 	; store msg in the EEPROM memory
#else
EEPROM $00, ("   Serial LCD   ") 	; store msg in the EEPROM memory
#endif
EEPROM $10, (" www.picaxe.com ") 	; store msg in the EEPROM memory
EEPROM $20, ("This is msg 2   ") 	; store msg in the EEPROM memory
EEPROM $30, ("This is msg 3   ") 	; store msg in the EEPROM memory
EEPROM $40, ("This is msg 4   ") 	; store msg in the EEPROM memory
EEPROM $50, ("This is msg 5   ") 	; store msg in the EEPROM memory
EEPROM $60, ("This is msg 6   ") 	; store msg in the EEPROM memory
EEPROM $70, ("This is msg 7   ") 	; store msg in the EEPROM memory
EEPROM $80, ("This is msg 8   ") 	; store msg in the EEPROM memory
EEPROM $90, ("This is msg 9   ") 	; store msg in the EEPROM memory
EEPROM $A0, ("This is msg 10  ") 	; store msg in the EEPROM memory
EEPROM $B0, ("This is msg 11  ") 	; store msg in the EEPROM memory
EEPROM $C0, ("This is msg 12  ") 	; store msg in the EEPROM memory
EEPROM $D0, ("This is msg 13  ") 	; store msg in the EEPROM memory
EEPROM $E0, ("This is msg 14  ") 	; store msg in the EEPROM memory
EEPROM $F0, ("This is msg 15  ") 	; store msg in the EEPROM memory
;initialise LCD
init:
	gosub LCD_init 		; initialise LCD
; display welcome message if desired
#ifdef use_welcome
	let b1 = 0			; message 0 on top line
	gosub msg			; do it
	low rs			; command mode
	let pinsB = 192		; move to line 2, instruction 192
	pulsout enable,1  	; pulse the enable pin to send data.
	high rs			; character mode again
	let b1 = 1			; message 1 on bottom line
	gosub msg			; do it
#endif
; main program loop, runs at 16MHz
	serin RX,baud,b1			; wait for the next byte
	; NB keep character mode test as first item in this list to optimise speed
	if b1 < 253 then
		let pinsB = b1 		; output the data
		goto main			; quickly loop back to top
	else if b1 = 254 then
		low rs 	     		; change to command mode for next character
		serin RX,baud,b1		; wait for the command byte
		high rs			; back to character mode
	else if b1 = 253 then
		gosub msg			; do the 16 character message
		goto main			; back to top
	else ; must be 255
		let pinsC = b1 & %00000111 | %10000000
						; output the data on C.0 to C.1, keep RS high
	end if
; power on LCD initialisation sub routine
LCD_init:
	let dirsC = %11000111	; PortC 0,1,2,6,7 all outputs
	let dirsB = %11111111	; PortB all outputs
#ifdef use_OLED
	; Winstar OLED Module Initialisation
	; according to WS0010 datasheet (8 bit mode)
	pause 500 			; Power stabilistation = 500ms
	; Function set - select only one of these 4 character table modes
	;let pinsB = %00111000 	; 8 bit, 2 line, 5x8 , English_Japanese table
	let pinsB = %00111001 	; 8 bit, 2 line, 5x8 , Western_European table1
	;let pinsB = %00111010 	; 8 bit, 2 line, 5x8 , English_Russian  table
	;let pinsB = %00111011 	; 8 bit, 2 line, 5x8 , Western_European table2
	pulsout enable,1  	;
	let pinsB = %00001100	; Display on, no cursor, no blink
	pulsout enable,1
	let pinsB = %00000001 	; Display Clear
	pulsout enable,1
	pause 7			; Allow 6.2ms to clear display
	setfreq m16			; now change to 16Mhz
	let pinsB = %00000010 	; Return Home
	pulsout enable,1
	let pinsB = %00000110 	; Entry Mode, ID=1, SH=0
	pulsout enable, 1
#else
	; Standard LCD Module Initialisation
	pause 15 			; Wait 15ms for LCD to reset.
	let pinsB = %00110000 	; 8 bit, 2 line
	pulsout enable,1  	; Send data by pulsing enable
	pause 5 			; Wait 5 ms
	pulsout enable,1 	 	; Send data 48 again
	let pinsB = %00111000 	; LCD  - 8 bit, 2 line, 5x8
	pulsout enable,1
	let pinsB = %00000001	; Clear Display
	pulsout enable,1
	pause 8			; 8 = 2ms at 16MHz
	let pinsB = %00000010 	; return home
	pulsout enable,1
	let pinsB = %00000110	; Entry mode
	pulsout enable,1
	pause 1
	pulsout enable,1
#endif
	high rs			; Leave in character mode
; display message from EEPROM sub routine
; message number 0-15 must be in b1 when called
; uses (alters) b1, b2, b3, b4
msg:
	let b2 = b1 & %00001111 * line_length
						; EEPROM start address is 0 to 15 multiplied by 16
	let b3 = b2 + line_length - 1 ; end address is start address + (line_length - 1)
	for b4 = b2 to b3			; for 16 times
		read b4,b1			; read next character from EEPROM data memory into b1
	next b4				; next loop
; Check end user has defined just one type of display
#ifndef use_OLED
#ifndef use_LCD
#error "Oops - no OLED / LCD type defined at top of program!"
#endif
#endif
#ifdef use_OLED
#ifdef use_LCD
#error "Oops - both OLED / LCD types defined at top of program!"
#endif
#endif
Did you remove the semi colon on the use LCD?
That pattern indicates a bad LCD. It is is simply faulty, we have seen one or two failures like that in the past.
You need a new LCD.
Yes, because of the photo. An LCD should never do that, and we have seen that type of failure before. We think it is normally because the glass is not making good contact with its own (LCD) PCB.
