CCTV Pelco-D controller
the old fart
This controls a cctv camera internal menu.
Can be expanded for Pan/Tilt
20M2 chip at 4800baud rate, to ST485CN and a keypad.
ST485CN
pin1 10k reistor to +5v
pin2 tied to +5v
pin3 tied to +5v
pin4 from C.0
pin5 tied to 0v
pin6 A to camera
pin7 B to camera
pin8 tied to +5v
no reistor A-B
SEN040 Data Entry Keypad
Pin C.1 to C1 keypad
Pin C.2 to C2 keypad
pin C.3 to C3 keypad
pin B.1 to R1 keypad
pin B.2 to R2 keypad
pin B.3 to R3 keypad
pin B.4 to R4 keypad
;cctv menu controller
; keypad 5 enter
; keypad 2 move up
; keypad 8 move down
; keypad 4 move left
; keypad 6 move right
;20M2
low b.1,b.2,b.3,b.4
symbol key_pos=b1
symbol key_value=b2
symbol display=b4
let display = 128
let key_pos=0
start:
scan:
let key_value=0
high b.1
gosub key_test
low b.1
let key_value=3
high b.2
gosub key_test
low b.2
let key_value=6
high b.3
gosub key_test
low b.3
let key_value=9
high b.4
gosub key_test
low b.4
goto scan
key_test:
if pinc.1=1 then add1
if pinc.2=1 then add2
if pinc.3=1 then add3
add3: let key_value=key_value+1
add2: let key_value=key_value+1
add1: let key_value=key_value+1
serout b.0,N2400,(254,display,#key_value,"   "); used for degugging only
if key_value=5 then gosub openmenu
if key_value=6 then gosub goright
if key_value=4 then gosub goleft
if key_value=2 then gosub goup
if key_value=8 then gosub godown
display=display+1
if display>148 then let display=128:endif
openmenu:
	serout c.0,T4800,(0xFF,0x01,0x00,0x07,0x00,0x5F,0x67)
goright:
	serout c.0,T4800,(0xFF,0x01,0x00,0x80,0x00,0x00,0x81)
goleft:
	serout c.0,T4800,(0xFF,0x01,0x01,0x00,0x00,0x00,0x02)
godown:
	serout c.0,T4800,(0xFF,0x01,0x00,0x40,0x00,0x00,0x41)
goup:
	serout c.0,T4800,(0xFF,0x01,0x00,0x20,0x00,0x00,0x21)
Thanks to all who helped with this project, cheers guys.
Dave
neiltechspec
Should you not also be issuing a stop command after every move, the camera will just keep moving if you don't won't it ?
Here's one I did for just controlling the Zoom on a box cam with integrated zoom lens.
#rem
Pelco D Zoom Controller (Cam ID 1) @ 9600,8,n,1
Using PICAXE 08M2 & MAX485
Wide command:
255 001 000 064 000 000 065 (start)
255 001 000 000 000 000 001 (stop)
Tele command:
255 001 000 032 000 000 033 (start)
pin C.0 is activity LED, flashes 10 times on power up & illuminates during button push
pin C.1 is 485 direction (pins 2&3), high for TX, low for RX
pin C.2 is 485 data out / in (pins 1&4), only using out in this app
pin C.3 is Tele button, active high
pin C.4 is Wide button, active high
#endrem
#picaxe 08m2
#no_data
Main:
	setfreq m16
	high C.1,C.2
	for b1 = 1 to 10
	high C.0
	pause 40
	low C.0
	pause 800
	next b1
	if pinC.4 = 1 then gosub Wide
	if pinC.3 = 1 then gosub Tele
	pause 400
Wide:
	high C.0
	serout C.2,T9600_16,(255,001,000,064,000,000,065)
	do until pinC.4 <> 1
	pause 800
	low C.0
	serout C.2,T9600_16,(255,001,000,000,000,000,001)
	pause 800
Tele:
	high C.0
	serout C.2,T9600_16,(255,001,000,032,000,000,033)
	do until pinC.3 <> 1
	pause 800
	low C.0
	pause 800
Neil.
