Iron man helmet using a AXE024
Jcdenton
Here is a bit of code that will allow you to control the 2 top servo's found in this video:
https://www.youtube.com/watch?v=4oEpHHu5Z18
init:
servo 1,75
servo 2, 225
if pin3 = 0 then goto main
Open:
servopos 1,225
servopos 2, 75
pause 3000
hold:
if pin3 = 0 then goto hold
servopos 1, 75
servopos 2, 225
pause 3000
MPep
Looks cool.
I never watched IronMan. Not my thing.
But at the end where you do the comparison, looks very impressive. Well done.
What PICAXE chip did you use?
Jcdenton
axe024 driver controller, i have also justr actually setup channel 4 to run the leds also. Ill update the code asap.
