I have 24 AXE023's all needing battery power.
Instead of rigging them all up to individual battery packs, I would like to use one battery pack if possible.
Two motors are rigged up to each board, so 48 motors. Only one motor will be used at any one time on each of the AXE023. So the possibility of 24 motors running at the same time.
Would this battery pack be suitable?
http://www.batteryspace.com/nimhbatterypack36v13ah3xfforev.aspx
Or would it fry everything? I am a total beginner - so don't really understand much about the amps etc. But here is what I figure:
1) each motor can draw up to 1/2 an amp- so I need around 12 amps
2) the battery pack seems to be 13 amps. Therefore it should be powerful enough.
3) Because the voltage is correct (3.6v) it won't catch on fire, because electronics only draw the amps they need? (Or am I very wrong?)
It has to be a fairly light battery and plugging it into anything else is not an option.
Thanks in advance for your help!
