rgb color fading code
Hey guys, I ask a lot of questions, but never share anything. So I thought i'de just share this code.
I was looking for code for an rgb led color fading, but couldnt find anything. I even posted a thread about it.
I ended up just writing it myself, so heres what I came up with.
It's nothing special, just code for fading through the color spectrum with an rgb led or led strip.
It slows down a bit when it nears or leaves a common color (roygbiv)
hope this helps someone somewhere.
symbol redpin = c.3		'pins selected for 20m2 chip
symbol greenpin = c.5
symbol bluepin = c.2
symbol pauseAmount = 10		'The higher, the slower
pwmout redpin, 100, 255		'initialize pwm
pwmout greenpin, 100, 0
pwmout bluepin, 100, 0
FadingToYellow:						'fades in green to make yellow
pause 200
b1 = 0
	gosub accelerationCheck				'a subroutine that makes it go slower when closer to a common color
	pwmduty greenpin, b1				'pwm output to a pin
	pause pauseAmount					'pauses to slow down the color fading
	if b1 = 255 then goto FadingToGreen		'goes to next color if fading is completed
FadingToGreen:						'fades out red to make green
pause 200
b1 = 0
	pwmduty redpin, b2
	pause pauseAmount
	if b1 = 255 then goto FadingToBlue
FadingToBlue:						'fades in blue to make blue
pause 200
b1 = 0
	pwmduty bluepin, b1
	pause pauseAmount
	if b1 = 255 then goto FadingToIndigo
FadingToIndigo:						'fades out green to make indigo
pause 200
b1 = 0
	pwmduty greenpin, b2
	pause pauseAmount
	if b1 = 255 then goto FadingToViolet
FadingToViolet:						'fades in red to make violet
pause 200
b1 = 0
	pwmduty redpin, b1
	pause pauseAmount
	if b1 = 255 then goto FadingToRed
FadingToRed:						'fades out blue to make red
pause 200
b1 = 0
	pwmduty bluepin, b2
	pause pauseAmount
	if b1 = 255 then goto FadingToYellow
AccelerationCheck:
if b1<=14 then						'checks to see if the fade is close to a common color (roygbiv)
		b1 = b1 + 1
	elseif b1<60 then
		b1 = b1 + 3
	elseif b1> 194 then
		b1 = b1 + 3
	elseif b1 > 239 then
		b1 = b1 + 1
		b1 = b1+5
	b2 = 255-b1						'makes b2 the opposite for fading out colors
