PICAXE Eagle Library
Hemi345
Eagle PICAXE Library
Hi all,
I wanted to share the CadSoft Eagle library I built for the current PICAXE microcontrollers.
The library includes footprints for both DIL and SMD versions of the 08M2, 14M2, 18M2, 20M2, 20X2, 28X2, and 40X2 chips.
Please see the screenshot below.
Extract PICAXE.lbr from the PICAXE.zip to use.
See post #6 below for latest version
Good work Hemi345.
While I use DIPTRACE, it is good to see others providing the work for others to use.
You could have just put the .lbr file into a zip archive and then folks can unzip to where they want/need and no need to change file names.
Would you like this thread moved to the completed projects area where it is not going to be "lost" in a sea of new threads anywhere near to quickly?
Hemi345
Thanks Westaust. I zipped up the library. If you would want to move it to the completed projects, that would be great.
