Technoman
Hi
In my search for a low cost reverse voltage protection, I made some experiments with various circuits including bipolar transistor, diode connected in serial mode, crow bar diode.
It came out that the circuit combining a cheap price and a low voltage drop (0V) is a crow bar circuit. I added a resettable fuse (Polyswitch) to protect the batteries.
But, there is a major drawback, although I never had any problem with the 20M (16F677) : in the case of a reverse voltage, the chip is exposed to a negative voltage (-1V) between VDD and VSS.
The Microchip specs is giving a -0.3 as the maximum reverse voltage.
The question is : what about the long time survival of the chips in a regular day to day use where this situation may occur. Any prediction? Any return on experiment?
I thought using a Schottky diode, but it is more expensive and they do have a quite high reverse leakage current.
Technoman
Technoman
