gbbickerton
I am using an 08M2 and find that the time variable is taking much longer than a second to update at 4 mhz do the serout and serin commands affect the timer variable?
Until you get a more definitive answer,I just ran into this problem myself and found this thread when looking for confirmation of what I found to be the case when using SEROUT while also using TIMER.
My question is what are all of the commands that can cause the TIMER variable to not increment normally?
From this thread, we know that SEROUT and SERIN affect it. From Manual 2 we can read that the SERVO command will affect the TIMER. What other commands will affect TIMER? PAUSE maybe?
Dave E.
