Binary to Numbers on 7 segs?
Bill Jones
I'm currently finding difficulties whilst writing a program.
I need to convert Binary digits into actual numbers on 2 seven seg displays.
Any tips?
Thanks,
Bill
Within the PICAXE, numbers are all threaded as binary irrespective of how we users notate them for ease of our understanding.
So binary %00110010 = hex $32 = decimal 50.
Exactly how do you need help?
Which PICAXE chip are you (going to) use?
How are the 7-seg displays connected?
Mtiplexed direct from PICAXE, driven via some other chip (which)?
The simplest scheme will be to take your number, break into the digits a high nybble (4-bits) and a low nybble then use a lookup table (see lookup command) to obtain the code to drive a digit of the 7-seg display
AllyCat
Hi Bill,
Welcome to the forum. Do you mean you wish to display a byte using Hexadecimal Characters on two seven-segment displays?
In princple, you can split the byte into nybbles with (e.g.) Let b2 = b1 / 16 and Let b3 = b1 // 16. Then you need to add 6 further "segment maps" into the LOOKUP list for the characters A, B, C, D, E and F. B and D need to displayed "lower case", i.e. b is a '6' with the top bar missing.
If you want/need to use a "decoder", you will need to choose one which supports A - F.
Do you have a schematic that might make things quicker for us to understand.
Are you using 1 and some multiplexing or 2 off 4511's across one port (ie the 8 x Port B outputs)
How are the other (non BCD) inputs of the 4511. Connected?
If there are two 4511 chips across 8 consecutive outputs (physical pins /1 to 28) the. With a binary or hex value you can just write the value direct to the 8-bit output port.
Outline = b5 for example
You also need to clarify the format of the "binary number".
Is it a BCD value in the range 0 to 99 or a raw binary number capable of values in the range 0 to 255 in which case there could be 3 digits
@Bill,
have a look at this thread here - started yesterday wherein aniother forum member has posted details for a M2 PICAXE part using a single 4511 and one transistor per 7-seg digit to drive a multi digit display.
http://www.picaxeforum.co.uk/showthread.php?23190-Multiplexing-7-seg-displays&p=230074#post230074
I note that your location is recorded as "lost" but without adequate information up front from you, folks here struggle to know exactly what the circuit and requirement is to provide a clear and concise anser without asking a lot of questions.
Trust the link provided helps in your quest.
