Configuring your new LCD can be challenging task, particularly if your model does not use a serial interface.
The attached code simplifies the task by specifying a universal piece of executable code with a few, separate lines of "Symbols" to define the function of each pin. The code is independent of hardware constraints: gone are the days where you have to connect specific pins to each other for the LCD to work!
The code is an ideal way to do an initial test of a new PCB or stripboard design incorporating an LCD.
This code is designed to run the parallel LCD in 4-bit mode. All you have to do is connect a total of 8 wires between your PICAXE and the parallel LCD module. This assumes that you have an LCD module that runs at the same voltage as the PICAXE - usually this is 4.5 or 5 volts.
Edit: Some LCD boards the R/W pin tied to 0v to ensure that your can only write to the LCD. If your LCD module does not tie this line low already, then you will need to do this. Refer to post #6 for options. The R/W pin is pin 5 on the three different LCD connectors that I'm aware of.
Next adjust the 8 Symbol commands to point to the outputs that you have connected your LCD inputs to. Note that the actual leg numbers on the chip will differ according to the model you are using. Refer to Manual 1 - "Getting Started" for pinout diagrams.
Save the code and download it to your PICAXE. If you have configured everything correctly, you shoud see the "Hello World!" message on your LCD.
- Two of the wires are obviously the Ground or 0v line and the +5v line.
- The 4 data lines (d4 - d7) and 2 control wires (Enable and Register Select) connect to any output pin that you have free on your PICAXE.
'Simple, flexible test routine for parallel LCDs (Tested on a 16 char x 2 row LCD)
'Should work on any PICAXE with 14 or more legs.
'#PICAXE 28X2 'Change to suit your processor
' **** Pins ****
' 4-bit mode: Uses a total of 8 wires between the PICAXE and LCD:
' 0v, +5v, Register Select and LCD Enable
' 4 data wires: Pins 4 to 7 on the LCD
' Flexible software:
' (practically*) any pin of the PICAXE can connect to any of the 6 control pins of the LCD
' *Note that leg 4 on the following PICAXEs is input-only and can't be used as an output
' Don't use 14M2/C.3; 18M2/C.5; 20M2/C.6 and 20X2/C.6
' After wiring up the LCD to the PICAXE (Data transfer is via pins 4 to 7 on the LCD),
' define the following symbols to their function.
' Note that the 4 data pins must be addressed in 2 two different ways
Symbol oLCDpin4 = outpinB.1 'B.1 for writing to the output pin directly
Symbol oLCD4 = B.1
Symbol oLCDpin5 = outpinB.5 'B.5 for writing to the output pin directly
Symbol oLCD5 = B.5
Symbol oLCDpin6 = outpinB.6 'B.6 for writing to the output pin directly
Symbol oLCD6 = B.6
Symbol oLCDpin7 = outpinB.7 'B.7 for writing to the output pin directly
Symbol oLCD7 = B.7
Symbol oLCDRS = C.0 'C.0 Register select: Low for Commands, High for Characters
Symbol oLCDEn = C.1 'C.1 Enable pin. Default condition is low. Pulse High to input data.
' There is no need to touch the code of the test routine!!
' After defining the above symbols, the code should compile, load and run. Simple!
' EEPROM and Message Pointer
Symbol eMsgStart = 0
EEPROM eMsgStart, ("Hello World!", 0)
' **** Test routine - Uses byte registers b0 and b1 ****
' DO NOT CHANGE THE CODE LISTED BELOW!
Init: 'Initialise the I/O Pins
Output oLCD4, oLCD5, oLCD6, oLCD7, oLCDRS, oLCDEn
'Initialise the LCD module
Low oLCDEn '(Default value is low)
Low oLCD7, oLCD6: High oLCD5, oLCD4 'Pattern %0011 ("Function Set")
PulsOut oLCDEn, 2 'Pulse enable pin 3 times to initialise
Pause 50 'Minimum 4.1mS (all clock speeds)
PulsOut oLCDEn, 2 '2nd Function Set
Pause 4 'Minimum 100uS (all clock speeds)
'Send a series of 8-bit commands to configure the LCD
b0 = %00110010 '$32 3rd Function Set, then 4-bit data, 2-line display
Gosub Cmd2LCD ' Send the command
b0 = %00001000 '$08 Reset Display to the selected mode
Gosub Cmd2LCD
b0 = %00001100 '$0C Turn the Display On with hidden cursor
Gosub Cmd2LCD
b0 = %00000110 '$06 Move the input (Ie "cursor") point after each character
Gosub Cmd2LCD
b0 = %00000001 '$01 Clear the Display
Gosub Cmd2LCD
Pause 35 '~4mS Required to let LCD clear (all clock speeds)
'Now send a simple "Hello World!" message to the LCD screen
b1 = eMsgStart 'Point to the EEPROM Massage
Read b1, b0 'Fetch the first character
Do 'Loop through this code to send each character
GoSub Chr2LCD 'Send the character to the LCD screen
Inc b1 'Move to next source location in EEPROM
Read b1, b0 'Fetch the next character
Loop Until b0 < " " 'Drop out of loop when first non-printing character is found
' ' (The space $20/32d/" " is lowest printable ASCII character)
Do: Loop
' **** Subroutine: Write a Single Byte to the LCD ****
' Two different entry points: Either send command or character to LCD
' Registers Used: b0 must be used due to bit addressing
Cmd2LCD: Low oLCDRS 'Point to command register (Otherwise defaults to character reg)
Chr2LCD: oLCDpin4 = bit4 'High nibble is sent first
oLCDpin5 = bit5
oLCDpin6 = bit6
oLCDpin7 = bit7
PulsOut oLCDEn, 2 'Clock 4 high bits of data into LCD
oLCDpin4 = bit0 'Followed by the low nibble
oLCDpin5 = bit1
oLCDpin6 = bit2
oLCDpin7 = bit3
PulsOut oLCDEn, 2 'Clock 4 low bits of data into LCD
High oLCDRS 'Next received byte defaults to displayable character
Return
