I need to receive an input pulse from an RC receiver, then set an output DAC 0 to 5 volts which will correspond to the 1000us to 2000us pulse in range. Then send a slightly different servo command to the servo. I'd use the DAC output on the 08M2 but I need better resolution than 32 steps. It might still be an option though.
I'm in the process of doing fuel injection on a large RC airplane 2 stroke motor. The ECU I'm using needs to see a 0 to 5 volt range for throttle position. Which is working well with pulsin and pwmout. Manual 2 states PWMOUT and servo command can not be used at the same time but nothing is mentioned about just plain old PWM command. Does PWM not use any of the interrupts or timers to function? Can I use PWM, pulsin and servo command together with out any timing/interrupt issues?
Thanks Ryan
Thanks Ryan
