Two days ago, i downloaded a simple debug ADC program onto my picaxe 20m2 to get adc values from an IR phototransistor.
The program downloaded successfully and a window opened showing the adc values. Then I closed that debug window and made a few changes to my IR phototransistor circuit. After making some changes I opened programming editor and selected Picaxe-> Debug... The debug window opened again and started showing the adc values, so far so good.
But now when I try to download a new program, it shows that same old error that "Hardware not connected, Hardware not powered", etc... I don't understand, the debug is still working properly which means that there is no problem in my usb cable and picaxe. I even tried with new batteries and tried the hard reset as explained in picaxe manual 1, but still the same result.
Any help will be greatly appreciated.
Thank you
readadc b.3, b0
debug
Thank you
