Hello, few days ago i just by my picaxe module 08m at picaxe website, when i finished assembly it then i connected to the usb and the programmer editor, but it doesnt detected(Hardware Not Detected), it said that maybe havent connected to power and the other else.
the port that u use is ready to use,
and this is how i soldered the 08m > i soldered all of the pin to the module without add-ing anything else, is that correct ? or i need another hardware to be soldered to the module, when i try to put the servo it seems move a bit
is there anything i can do to this module to make it read-able ?
Thank you so much
Thank you so much
