Hi all,
I've been searching the forums and just wanted to confirm the best ways to conserve power whilst waiting for an input (I'm using an 08M2).
Currently I have the following:
- Setting the frequency to as low as possible (k31)
- nap for as long as possible during the 'waiting for input' loop
I've seen it mentioned that all unused pins should be directly connected to ground - Is this correct? Do they need to be set low in the programming or is this (as I assume) automatically done?
Are there any other things I can do to ensure minimum battery drain?
Thank you in advance and apologies for bringing up relatively common discussion.
