Results 1 to 4 of 4
Thread: Robot Arm Printer
  1. #1
    Join Date
    Jul 2011
    Location
    Los Angeles, CA
    Posts
    572
    Default Robot Arm Printer
    Early test of a 3-servo robot arm for drawing. Rotary joint distortion causes distinctive look. BS2 shown in these initial tests, but ultimately this will be a 20M2 project, accepting input through a PS2 keyboard and printing ASCII characters.
    First test at http://www.youtube.com/watch?v=uNIURBikrr8
  2. #2
    Default
    I like this, it could be good for "drawing" circuits for etching.
    Tweaking to move servo together to get straight lines is probably easier than the file translations to get a suitable output from PCB programs.
    Best regards,
    Colin
    Just spotted a Tutorial for getting an isolation profile for milling as Gerber File from Eagle CAD. This would make PCB drawing much easier... I might have to try reproducing your arm for this
    http://www.fablabmanchester.org/p75/...utorialNEW.pdf
  3. #3
    Default
    I should strike the comment on isolation profiles... you don't want that for a Pen but you might for a cutter. Both can be handled in Eagle CAD.
    Using the CAM processor and HPGL as the device you can set your pen width to get a simple text file to describe the lines to be drawn. I under stand the plotter units (plu) used are 40 plu per millimeter and 1,016 plu in one inch. From a simple test most pads, tracks and text was made from straight lines - simple point to point with pen up or down... there was only the mounting hole that was drawn as a circle - I think that's the hard one.
    I've got to find time for this project
    Best regards,
    Colin
  4. #4
    Join Date
    Jul 2011
    Location
    Los Angeles, CA
    Posts
    572
    Default
    I had this setup working at Parallax's Expo for National Robotics Week, so I used a Parallax BS2. I didn't dwell on the fact that I used a PicAxe 20M2 up front to read the keyboard and create a macro that auto-typed "Parallax Expo 2012". I'll port it all over into the 20M2 pretty soon.
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
