pepijndevos
I found out how to make my own moisture sensor, but it needs to run on AC, to avoid electrolysis.
I also figured out I need a precision rectifier to be able to measure the resistance over the moisture sensor.
The problem is that I'm a little confused how the ground works with respect to the AC source(some sort of adapter).
So I connect a PICAXE through a capacitor and a rectifier to the AC source. Then I put AC on the sensor, and connect that through an precision rectifier(and a capacitor?) to the PICAXE input.
But how?
But how?
