I have a picaxe 08m2 in a small breadboard. Leg 2 has a 10k resistor connected to 0v and i have a 470ohm resistor protecting an led on leg 7. I'm using a USB cable to power the picaxe so its about 5 volts. I was told to connect a little capacitor from 5v-0v for stability i think. The led wont light up and i know that it is a working led. I wasn't sure if you needed a 10k or 22k on leg 2 so i tried 10, then 22, then both connected to 0v and nothing happens still. Lighting an LED in electronics is the equivalent to outputting Hello World in programming yet i still can't do it.
How can i produce a schematic instead of taking photos?
