It's not Programming Editor, but it's my play at using
Rev-Ed's VB.net example compiler use and it provides core functionality like saving, opening, syntax check and programming. As it uses .NET 2.0, it will run on Windows 98 as long as the .NET framework is installed.
To use, simply unzip the program from the attached zipped folder, put the compilers from
here into a folder called 'compilers' in the same directory as the executable and run the executable. Including the compilers in the zipped folder attached goes against Rev-Ed's licensing rules and they exceed the forum file size limit anyway.
Unfortunately, it is quite primitive compared to Programming Editor regarding the functionality of the text editor - no line numbers, no colour syntax and no automatic tabs.
Also consider downloading my PICAXE Calculator program for wizards/calculators for, currently, the compsetup, hintsetup, settimer, tmr3setup, adcconfig, dacsetup and hsersetup commands. Get it in
this post.
The editor does, however, gets rid of the message box that appears after each download in favour of a small textbox at the bottom of the window but in the image above you can't see it as it is resized to the minimum size with the thin bar you can see.
