I have a problem with my build of this project, can anyone help me please? I am a reasonable novice but I can understand the concept of the darlington and optocoupler etc. Plus I do coding for a living, though obviously not this form of Basic.
Firstly, the PSD is excellent, however I had to ungroup the 'joining wires' layer to make each sub layer visible, otherwise the grouped layer was invisible in CS5.1. This may need to be re-done or noted somewhere. Also no motor connections on the PSD. Though the 4 outs on the Darlington are fairly straightforward finding the right 'common' line was not so easy for me. Stepper motors are new to me.
OK, I'm using the 08M2. Status of problem. I can't get any response, not even a shudder from the motor. Power is definitely getting to it as it's holding solid (can't physically turn it, and I can feel vibratory resistance). Testing each wire on the motor out of circuit produces expected shudder, and the motor is brand new. One thing with the motor is that I'm presuming Phase A is step 1, Phase /A is step 2, Phase B is 3, /B is 4. Motor datasheet on below link to my website, where circuit pics, .bas file etc are.
I've cleared the channels between strips with a fine screwdriver, measured the resistance of all connections and components. On power up, even without sending any IR via the remote I have the situation where the stepper is in 'hold' mode.
I've used two different power supplies, 3x NiMh and a 4.5v powerpack cut down to 4.1v with a commercial fan speed controller. I've measured the outputs and inputs of chips and the line to the stepper. All parts were bought from an electronic store, not e-bay. I've upped the capacitor to a 100uF 10v electrolytic as motor current is 1.1A per phase, this capacitor is correctly mounted for a polarised capacitor. I also programmed the Picaxe 08M2 on the beginner kit board rather than the project board, to minimise component interference. The program is exactly as original (cut and paste) and works in simulation. Programming the chip went without a hitch, no errors. All the chips were put in after all soldering, so no heat issues.
I measured voltages across the board without the motor connected, see my website link below for Excel file Voltages Measured.
Hi Res pictures of the board top and underneath, bas file, measured voltages and motor datasheet are
http://members.iinet.net.au/~rextal/Picaxe cd macro rail/
Help would be greatly greatly greatly appreciated as I now have a MPE65 which not having an autofocus system, and hence motor, cannot be controlled via Helicon Remote, which is my usual tool of choice for remote control to take focus bracketed shots.
