When inserting a block start character "{" in line 1 and block end character "}" a few lines further down and then save the program, you will experience a disaster when you start the program again. Almost the entire program has disappeared. Only the top line and a few other lines are back, and these are all located in one long line.
The problem exists only when the block start character "{" is located at line 1
I've observed the problem in version 5.4.2 as well as in 5.4.3, it is also observed in both Windows XP and Windows 7
I was so lucky that I had just backed up all my data, otherwise, I had lost 256 lines of coding.
William
William
