Thought this heads up may be of interest - perhaps even an answer to someone's needs?! Here's Dorji's spiel-
The companion DRF4432S receiver has the same hardware as Dorji's DRF4432D20 transceiver, but software differs so they're not compatible. More details => www.dorji.com/docs/data/DRF5150.pdf Stan.
Configuration is via "DRF_Tools_5150" software. Infineon's TDA510 RF IC is used (although this may be nearing obsolescence?) Module costs estimated in US$10-$20 range. Note that they can work in two modes-the simple direct Analogue Sensor mode as well as normal micro based serial data transmission.The DRF5150s module integrates 12bit high resolution ADC which can be used to connect different types of analogue or digital sensors - PT1000 (thin film platinum resistance), Dallas Semi/Maxim DS18B20(digital temperature), Sensirion SHT21/25(humidity) etc. Users don’t need to write codes between sensor and DRF5150S module, and no external MCU or other components are needed.
For the simplest application users can solder a sensor to the pins of DRF5150 module to build a wireless sensor transmitting system easily. The module can collect data from sensors and send it to the companion receiver module DRF4432S at configurable intervals, which minimizes the BOM cost and reduces development time for new projects.
