​ ​ ​ ​ 08M2 TX/RX Project
Page 1 of 10 1 2 3 ... LastLast
Results 1 to 10 of 97
Thread: 08M2 TX/RX Project
  1. #1
    Join Date
    Oct 2011
    Location
    New England
    Posts
    20
    Default 08M2 TX/RX Project
    Hey everyone,
    I have two breadboards setup with the attached circuits and I am using these transmitter and receiver chips, http://www.sparkfun.com/products/10533 and http://www.sparkfun.com/products/8945. I want to trigger an LED on the receiver side to flash once a mercury switch is tripped on the transmitter side, so pretty simple. I have come a very long way with this project as I have absolutely no prior experience with any of these components or this specific programming language but I am at a bump in the road. I want to flash the LED as long as the mercury switch is connected and when the switch is reset I want the flashing to stop. Here is the code I have for both the transmitter and receiver:
    Transmitter code:
        if pinC.3 = 1 then alarm
    alarm:
        SEROUT 2,N4800,(1)
        if pinC.3 = 0 then main
        goto alarm
    Receiver code:
    	SERIN 3,N4800,b1
    	if b1 = 1 then flash
    flash:
    	high C.2
    	pause 100
    	low C.2
    	pause 100
    I can get the LED to flash a single time when I hold the switch down but it will not continue flashing. I know there is a programming error somewhere because I am not familiar with how a system like this works with sending the data and everything. I believe the use of an interrupt could permit the function I am looking for but I am not sure how to use it in this situation.
  2. #2
    Join Date
    Mar 2011
    Location
    Connecticut, USA
    Posts
    188
    Default
    It looks to me that you added your transmitter code twice and did not include your receiver code.
    Joel
  3. #3
    Join Date
    Oct 2011
    Location
    New England
    Posts
    20
    Default
    Why yes I did, thanks for catching that.
    Just updated the post with the receiver code.
  4. #4
    Join Date
    Mar 2011
    Location
    Connecticut, USA
    Posts
    188
    Default
    Looking at some of the info on the modules that you are using, I would suggest that you use t4800 (non-inverted) serial output instead of the n4800 (inverted) serial out that you tried. Before you send any data set your serout pin high (high c.2).
    Try that, It may help.
    Joel
  5. #5
    Join Date
    Mar 2010
    Location
    italy
    Posts
    2
    Default re
    transmitter code:
    alarm:
        SEROUT 2,N4800,(1)
        if pinC.3 = 0 then
         SEROUT 2,N4800,(0)
        goto alarm
    Receiver code:
    	SERIN 3,N4800,b1
    	if b1 = 1 then
    	high C.2
    	pause 100
    	low C.2
    	pause 100
    evidence in this way
    excuse for English but I'm Italian
    use google to translate
  6. #6
    Default
    If you look through past entries in this forum, you will find that users of wireless TX/RC systems strongly encourage a known prefix to the data in order for the receiver to "train" itself to the signal from the transmitter and to reject spurious noise.
    Also, your code could use some optimizing. So, with that in mind, I suggest...
    ' Transmitter code
      if pinC.3 = 1 then
        SEROUT 2,N4800,("ABC", 1)
      end if
    ' Receiver code
      SERIN 3,N4800,("ABC"), b1
      if b1 = 1 then
        high C.2
        pause 100
        low C.2
        pause 100
      end if
    The transmitter code should continuously transmit as long as the button is held down. The transmitter will flash the LED every time it receives a transmission.
  7. #7
    Join Date
    Oct 2011
    Location
    New England
    Posts
    20
    Default
    Both of those codes just flash the LED one time while I hold the switch down and the T4800 doesn't work at all.
    Hmm, not sure what is going wrong.
    Thanks for the help.
  8. #8
    Join Date
    Jan 2009
    Location
    Flitwick, Buckinghamshire
    Posts
    330
    Default
    if you look at the walkthru on the sparkfun site it says non inverted serial connection (N2400)
    http://www.sparkfun.com/datasheets/R...alkthrough.pdf
    if you search the forum for "rf module" there are loads of examples.
    Using a preamble and a qualifier in the code will help the modules to decipher each other from noise in this band.
    from memory Stan Swan (AKA manuka) is the guru on this subject !
    Regards
    Neil
  9. #9
    Join Date
    Oct 2011
    Location
    New England
    Posts
    20
    Default
    Thanks! I wasn't quite sure what to search for but I will do that right now.
    EDIT: After a little research, do I need to add the 10k and 22k resistors to my schematic and breadboard like in this schematic?
    Thanks!
  10. #10
    Join Date
    Oct 2011
    Location
    New England
    Posts
    20
    Default
    Do you believe adding those would fix my problem? I have been struggling with this project for the greater part of a month now and have done a lot of research but I am a mechanical engineer by trade so this stuff does NOT come easy to me.
    Thanks!
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
