All about my 18M2 Robot Hand
erco
Great job! Just how often does that middle finger salute "randomly" come up? :)
IronJungle
Ha! The finger is random. I promise. The "Walk" sub that waves the fingers comes up a bit more often.
Here is my spaghetti code to prove it:
' PICAXE 18M2 for Hand Gesture Robot JULY 2011
' www.ironjungle.com
' Other than the minium PICAXE 18M2 'keep alive' 22K R & 10K R
' no other R, C, L, etc need for the project.
' Everything powered by 4.5VDC
' The PICAXE drives the servos straight from the chip.
' See pinouts in comments
' 0 is Thumb (PICAXE pin 6)
' 1 is Pointer (PICAXE pin 7)
' 2 is Middle (PICAXE pin 8)
' 3 is Ring (PICAXE pin 9)
' 4 is Pink (PICAXE pin 10)
' Normallu Open Button Switch is PICAXE pin 18 (pulled HIGH with 10K)
'Define Servo values to fully EXtend/Open finger
Symbol Ex_Thumb = 60
Symbol Ex_Pointer = 60
Symbol Ex_Middle = 245
Symbol Ex_Ring = 60
Symbol Ex_Pink = 60
'Define Servo values to fully CLose finger
Symbol CL_Thumb = 225
Symbol CL_Pointer = 240
Symbol CL_Middle = 50
Symbol CL_Ring = 240
Symbol CL_Pink = 240
'Init the servos
servo 0, Ex_Thumb
servo 1, Ex_Pointer
servo 2, Ex_Middle
servo 3, Ex_Ring
servo 4, Ex_Pink
pause 400
'Gesture Subroutines are:
'  One
'  Two
'  Three
'  Four
'  Open_Hand
'  Hook_em
'  Gig_em
'  Hang_Loose
'  Fist
'  F_You
'  Walk
'Insure Open_Hand position and
'Turn the servos off so they don't jitter
gosub Open_Hand
pause 400
servopos 0, off
servopos 1, off
servopos 2, off
servopos 3, off
servopos 4, off
do until pinC.1 = 1 'wait for RED button press (PICAXE pin18)
	RANDOM w12	' w13 will be use to in Case Statement
	w13 = w12 // 11 + 1 '"//" is modulus divide (returns remainder)
'Turn the servos on. We turned them off so they didn't jitter
'Hand is already in the Open_Hand position
servo 0, Ex_Thumb
servo 1, Ex_Pointer
servo 2, Ex_Middle
servo 3, Ex_Ring
servo 4, Ex_Pink
Select Case w13
	Case 1
		gosub One
	Case 2
		gosub Two
	Case 3
		gosub Three
	Case 4
		gosub Four
	Case 5
		gosub Hook_em
	Case 6
		gosub Gig_em
	Case 7
		gosub Hang_Loose
	Case 8
		gosub Fist
	Case 9
		gosub F_You
	Case 10,11    'add cases so this will come up more often
		gosub Walk
endselect
pause 3000 ' hold the selected gesture
goto main   'return and wait for button press
' Gesture Subroutines below:
Open_Hand:
servopos 0, Ex_Thumb
servopos 1, Ex_Pointer
servopos 2, Ex_Middle
servopos 3, Ex_Ring
servopos 4, Ex_Pink
return ' Open_Hand
Gig_em:
servopos 1, CL_Pointer
servopos 2, CL_Middle
servopos 3, CL_Ring
servopos 4, CL_Pink
return 'Gig_em
Hook_em:
servopos 0, CL_Thumb
servopos 3, CL_Ring
servopos 4, Ex_Pink
return 'Hook_em
F_you:
servopos 3, CL_Ring
servopos 4, CL_Pink
return 'F_you
One:
servopos 3, CL_Ring
servopos 4, CL_Pink
return 'One
Two:
servopos 3, CL_Ring
servopos 4, CL_Pink
return 'Two
Three:
servopos 3, Ex_Ring
servopos 4, CL_Pink
return 'Three
Four:
servopos 3, Ex_Ring
servopos 4, Ex_Pink
return 'Four
Fist:
servopos 3, CL_Ring
servopos 4, CL_Pink
return 'Fist
Hang_Loose:
servopos 3, CL_Ring
servopos 4, Ex_Pink
return 'Hang_Loose
Walk:  'waves the fingers
pause 70
pause 70
pause 70
servopos 3, CL_Ring
pause 70
servopos 4, CL_Pink
pause 70
pause 70
pause 70
pause 70
servopos 3, Ex_Ring
pause 70
servopos 4, Ex_Pink
return 'Walk
Well done Iron Jungle. :)
Your code is quite well done for a newcomer with good set of remarks at the start.
I have taken the liberty of providing a tweaked version using the ON...GOSUB rather than SELECT...CASE command which saves some bytes of program space.
This also means you do not need the "+1" on the end of the calculation usd for the case.
Also put the open hand within the main loop as a GOSUB call to the already existing routine
These program changes save over 100 bytes of program space and will not significantly if at all effect the operation of the project.
Finally indented the actual code so only SYMBOL statements and Labels start in the first column on each line and put the BASIC command functions in capitals (demo of a personal preference for perceived better program listing readability).
; PICAXE 18M2 for Hand Gesture Robot JULY 2011
; www.ironjungle.com
; Other than the minium PICAXE 18M2 ;keep alive; 22K R & 10K R
; no other R, C, L, etc need for the project.
; Everything powered by 4.5VDC
; The PICAXE drives the SERVOs straight from the chip.
; See pinouts in comments
; 0 is Thumb (PICAXE pin 6)
; 1 is Pointer (PICAXE pin 7)
; 2 is Middle (PICAXE pin 8)
; 3 is Ring (PICAXE pin 9)
; 4 is Pink (PICAXE pin 10)
; Normally Open Button Switch is PICAXE pin 18 (pulled HIGH with 10K)
;Define SERVO values to fully EXtend/Open finger
SYMBOL Ex_Thumb 	= 60
SYMBOL Ex_Pointer	= 60
SYMBOL Ex_Middle 	= 245
SYMBOL Ex_Ring	= 60
SYMBOL Ex_Pink	= 60
;Define SERVO values to fully CLose finger
SYMBOL CL_Thumb	= 225
SYMBOL CL_Pointer	= 240
SYMBOL CL_Middle	= 50
SYMBOL CL_Ring	= 240
SYMBOL CL_Pink	= 240
;Init the SERVOs
SERVO 0, Ex_Thumb
SERVO 1, Ex_Pointer
SERVO 2, Ex_Middle
SERVO 3, Ex_Ring
SERVO 4, Ex_Pink
PAUSE 400
;Gesture Subroutines are:
;  One
;  Two
;  Three
;  Four
;  Open_Hand
;  Hook_em
;  Gig_em
;  Hang_Loose
;  Fist
;  F_You
;  Walk
Init:
	GOSUB Open_Hand
	PAUSE 400
Main:
;Insure Open_Hand position and
;Turn the SERVOs off so they don;t jitter
	SERVOPOS 0, off
	SERVOPOS 1, off
	SERVOPOS 2, off
	SERVOPOS 3, off
	SERVOPOS 4, off
	DO
		RANDOM w12	; w12 used to create w13 that will be use to in ON....GOSUB Statement
	LOOP UNTIL  pinC.1 = 1 ; wait for RED button press (PICAXE pin18)
;Turn the SERVOs on. We turned them off so they didn;t jitter
;Hand is already in the Open_Hand position
	GOSUB Open_Hand
	w13 = w12 // 11 [COLOR="#FF0000"]; + 1[/COLOR] ;"//" is modulus divide (RETURNs remainder)
	[COLOR="#FF0000"]ON w13 GOSUB One, Two, Three, Four, Hook_em, Hang_Loose, Fist, F_You, Walk, Walk[/COLOR]
	PAUSE 3000 ; hold the selected gesture
	GOTO Main   ; return to the start of Main loop and wait for button press
; Gesture Subroutines below:
Open_Hand:
	SERVOPOS 0, Ex_Thumb
	SERVOPOS 1, Ex_Pointer
	SERVOPOS 2, Ex_Middle
	SERVOPOS 3, Ex_Ring
	SERVOPOS 4, Ex_Pink
	RETURN ; Open_Hand
Gig_em:
	SERVOPOS 1, CL_Pointer
	SERVOPOS 2, CL_Middle
	SERVOPOS 3, CL_Ring
	SERVOPOS 4, CL_Pink
	RETURN ;Gig_em
Hook_em:
	SERVOPOS 0, CL_Thumb
	SERVOPOS 3, CL_Ring
	SERVOPOS 4, Ex_Pink
	RETURN ;Hook_em
F_you:
	SERVOPOS 3, CL_Ring
	SERVOPOS 4, CL_Pink
	RETURN ;F_you
One:
	SERVOPOS 3, CL_Ring
	SERVOPOS 4, CL_Pink
	RETURN ;One
Two:
	SERVOPOS 3, CL_Ring
	SERVOPOS 4, CL_Pink
	RETURN ;Two
Three:
	SERVOPOS 3, Ex_Ring
	SERVOPOS 4, CL_Pink
	RETURN ;Three
Four:
	SERVOPOS 3, Ex_Ring
	SERVOPOS 4, Ex_Pink
	RETURN ;Four
Fist:
	SERVOPOS 3, CL_Ring
	SERVOPOS 4, CL_Pink
	RETURN ;Fist
Hang_Loose:
	SERVOPOS 3, CL_Ring
	SERVOPOS 4, Ex_Pink
	RETURN ;Hang_Loose
Walk:  ;waves the fingers
	PAUSE 70
	PAUSE 70
	PAUSE 70
	SERVOPOS 3, CL_Ring
	PAUSE 70
	SERVOPOS 4, CL_Pink
	PAUSE 70
	PAUSE 70
	PAUSE 70
	PAUSE 70
	SERVOPOS 3, Ex_Ring
	PAUSE 70
	SERVOPOS 4, Ex_Pink
	RETURN ;Walk
Marcwolf
Very nice. I was impressed by the smooth motion of the fingers and that you were able to get as much movement from a standard servo.
One of the issues re the plastic servo gears is that they can strip easily - but you can buy metal gear units very cheaply on EBay nowadays to get over that issue.
Getting feedback from the hand re pressure of grip would be interesting and there are a range of sensors that can help you with that. http://littlebirdelectronics.com/collections/sensors/flex
From the longer flex sensors as a feedback that the servo has not stalled, to the pressure sensors that you can use on the fingertips and in the palm to guage when the hand has gripped something.
But again - an excellent job.
Take care
Marc
@ IronJungle : Excellent job and you might like to consider uploading to the PICAXE Project Gallery ...
http://www.picaxe.com/Project-Gallery/Submit
Every month we're giving a prize away for the most interesting / amusing / innovative project and the same for one lucky winner from all who upload their project. Pretty good prizes as well ...
* AXE091 Experimenter Board
* PICAXE-20X2 Microbot
* PICAXE-28X2 Module
All entrants need to do is write a brief description of their project, have an uploadable photo of it, ideally have a youtube video of it ( but that's not essential ), and that's pretty much it.
Big or small, complex or simple; put your PICAXE project on show !
IronJungle
Thanks for the suggestion. I will do that. The prizes are cool and I want to support the forum.
LED Maestro
Ha! Yep it is a great project. So simple yet very effective. Thanks for the link. Will be looking to see when they are back in stock.
