reddiesel41264
Hi, I'm sure this is an easy one.
I have an IR LED with a forward voltage of 1.7v, and forward current of 100mA. My picaxe circuit uses a 28x1 chip. Im using a 9V supply which is regulated, via a 7805 chip, to 5v.
In order to get the most brightness from the LED should I connect it straight up to the output pin of the chip (with an appropriate resistor of course) or should I use a transistor to get more current to it?
Thanks
Thanks
