Three I/O ports would suggest SPI.Also, I have no idea what they mean by "three I/O ports." Serial? Parallel? USB?
Con-coat is easily removed with standard flux cleaner, ie iso-alcohol and a stiff brush. I doubt they are coated in any case.For either of those changes, make sure the bds are not already conformal coated. Though I suspect they are not, conformal coating can be a real pain to do mods through and makes many changes virtually impossible.
Not to get too far off the subject, but a correction to this comment may be in order here. Acrylic, Epoxy, Polyurethane, Silicones, Parylene, and Amorphous Fluoropolymer are all used for conformal coatings. Not all of them are easily removed with common solvents.Con-coat is easily removed with standard flux cleaner, ie iso-alcohol and a stiff brush. I doubt they are coated in any case.
Texy
It appears that we (the electronics community) are going to have to learn Mandarin! http://blog.makezine.com/archive/2011/07/why-every-maker-should-learn-chinese.htmlIt could give you an excuse to head to your favourite Chinese restaurant on the grounds of seeking 'translation services'
I suspect that the "Digital tube" is the 7-segment LED display.I assume that a "digital tube" is the thru-hole LED.
Please figure 'em out quick, so I can buy a couple before they're all sold out.Looks like it might be a nightmare to get working with the limited documentation.
I just ordered 2.
You suggesting we help 'prop up the Chinese economy'?Just buy one and get on with it
