FRM101 LCD firmware chip
A quick question for Technical or hippy.
Is there any limitation, within reason, on the length of a row of characters if one uses the FRM101 LCD controller chip?
Many of us have 16x2 and 20x4 LCD displays.
Can, for example, the FRM010 be used with a 24x2 display?
I ask this because, by way of example, the Spark fun SerLCD V2 backpack which has been used by some forum members here in the past as part of Sparkfun LCD modules does have a definite limit to number of characters per line (it can be 16 or 20 characters).
You can use any size e.g. 16x2 20x2 40x2, 20x4 (remembering that a 20x4 is always electrically made as a 40x2, ie lines 1 and 3 are the virtual top line and 2 and 4 are the virtual bottom line)
So a 24x2 should also work fine.
BillyGreen1973
as far as I can tell, each character sent to the display is dealt with and displayed as it is recieved. So in other words, the input buffer is 1 character long, and because the firmware is written in assembler it is quick enough to display that character before the next one arrives.
I could be very wrong, but thats how it seems to operate.
Westaust, I'm not teaching you to suck eggs, just adding detail for other readers;)
Thanks Technical & Eclectic.
Having identified the limitation in the "other" LCD backpack where the supplier could only suggest I re-program their on board firmware chip to suit, I just wanted to ensure there was no such "hidden" limitation with the FRM010.
Having built 1-Wire network and shift register based home brew LCD interfaces in the past, the requirements to drive the actual LCD are understood
@BG,
Never a problem with someone adding their comments.
You never know when such a comment may just add that exta bit of information to the knowledge bank :)
EDIT:
Based on the response(s) I will proceed to purchase a couple of FRM010's from my "local" friendly outlet (MicroZED) who are only ~0.25 of a world away :)
Thanks westaust55! You answered 2 different posts (with perfect answers) in just a few minutes. I'm going to double the rate I'm paying you! :)
nick12ab
Serial LCD Firmware Documentation Errors
Just thought I ought to point this out, but for the heading for the contents, it says 'Serial Printer Firmware Contents' rather than 'Serial LCD Firmware Contents'.
Confirmed.
The FRM010 datasheet has a carry over from the FRM015 Printer interface chip.
Rev Ed will no doubt action a correction in due course.
@nick: I was looking under products & modules at http://www.rev-ed.co.uk/picaxe/ Seems like it should be mentioned there, with the other ICs for clocks, EEPROMS & motor driver.
@peter: I found your chip yesterday, it's perfect. I will be placing an order Tuesday once the banks open and I can can transfer money. I totally drained my Paypal account Saturday when I won this new toy on Ebay:
http://www.ebay.com/itm/160643186282 An unbuilt Heathkit HW-9. Now I have to decide whether to build it or save it!
it was for erco's post:and it was a rhetorical question about him not being able to find something that was in plain sight.
Thanks for the shoutout, Nick. Way to make this newcomer feel welcome! Are Brits only polite in person? :)
nick12ab
I'm sorry if I offended you but it's also common sense to do a search in Techsupplies for FRM010 which does come up with the chip you're after, plus you're now a senior member. I don't react that way for questions that don't have such obvious answers and probably almost everyone will have or will say something wrong or ask something obvious.
For the Serial LCD datasheet error post, I could have instead of pointing out the error had said 'Can erco guess what's wrong with this?'
Dippy
Nick, the first comment was more sarcastic and not really rhetorical.
But if I were you I'd quit while you're behind :)
It'll be interesting to see how politely you react when someone is sarcy to you...
erco; Nick is a youngster so maybe let him off easy this time please.
The Internet sometimes encourages people to say things that they wouldn't say face-to-face.
All's good, Dippy. We Yanks are thick-skinned as a rule. Thanks for intervening.
Nick, I'll bet you're a smart guy, but your effort to shame me was simply wasted time. Had that time & effort gone into something constructive, the world would be a better place. BTW, I earned my newfound "senior member" status (100 posts) during these last few posts bantering with you. Cheers, mate!
nick12ab
Confirmed.
Comparing the datasheets for both, the contents list is different and the rest of the datasheet has nothing inn common so I'm surprised this went unnnnoticed when they would have only been copying and pasting a couple of lines (note that the datasheet hasn't been corrected yet).
