​ ​ ​ ​ External Hard Reset for 18m2
Results 1 to 9 of 9
Thread: External Hard Reset for 18m2
  1. #1
    Join Date
    Oct 2009
    Location
    Bramley, Surrey, UK
    Posts
    246
    Blog Entries
    7
    Default External Hard Reset for 18m2
    I need an external hard reset of the 18m2. Can I get advice on the how to do this?
    I have 08m external hard reset circiut and I am looking to for the same circuit (if possible) for the newer device.
    Thank you in anticipation.
    Anobium
  2. #2
    Join Date
    Jan 1970
    Location
    UK
    Posts
    23,908
    Default
    There's no way to add a true external hard reset to an M2 PICAXE other than using a means to cut power and restore it.
    The 'reset' on leg 5 of earlier 18-pin PICAXE is just another input (C.5) on the 18M2. You can interrupt on it going low, poll it, and issue a RESET command when it goes low, even put that in a separate task, so it acts like a reset input, but that won't help if the PICAXE is in a blocking command.
    As you've got an external reset circuit for the 08M I'd have thought it would be the same for the 18M2. As you've already got it for the 08M I'm a little confused as to what you are asking for.
  3. #3
    Join Date
    Oct 2009
    Location
    Bramley, Surrey, UK
    Posts
    246
    Blog Entries
    7
    Default
    I am looking for validation of the 08m approach (see attachment).
    Will this work for 18m2? which pyhsical pins to use? and, are there any dangers etc?
    Attached Images Attached Images
  4. #4
    Join Date
    Jan 1970
    Location
    UK
    Posts
    3,043
    Default
    That circuit will work in most situations.
    However, it won't react while blocking commands have been issued - so use serin, infrain etc, and the reset will no things (in the same way that an interrupt on C.5 would do nothing).
  5. #5
    Join Date
    Oct 2009
    Location
    Bramley, Surrey, UK
    Posts
    246
    Blog Entries
    7
    Default
    @andrew. Thank you. Can I clarify? Where can I find a list of blocking commands? And_ may I ask you to review the last sentence. I cannot understand.
    Cheers
  6. #6
    Join Date
    Jan 1970
    Location
    UK
    Posts
    3,043
    Default
    In other words, your method would have the same limitations.
    I'm not aware of a list of blocking commands anywhere, but ones I can think of include:
    - rfin
    - serin
    - infrain
    - keyin
    Andrew
  7. #7
    Join Date
    Jan 1970
    Location
    UK
    Posts
    23,908
    Default
    Some PAUSE, SLEEP and COUNT can block for significant amounts of time, and also SERRXD and DISCONNECT are permantly blocking ( until RECONNECT issued or power-cycled ).
  8. #8
    Join Date
    Jan 1970
    Location
    Bath,UK
    Posts
    6,418
    Blog Entries
    1
    Default
    A push to break switch on the power rail will also very simply do the job!
    PICAXE Technical Support
  9. #9
    Join Date
    Oct 2009
    Location
    Bramley, Surrey, UK
    Posts
    246
    Blog Entries
    7
    Default
    @Technical.
    I am using an AXE091 board and I require an 08m to trset the 18m. Currently I am connecting and reconnecting the power to all devices. So, I need to reset single devices not the whole board.
    I will try the 08m circuit and report back.
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
