Howdy PicAxe community! Thanks for helping a newcomer with several problems. Here's a little payback that may be useful to someone.
I've used a 18M2 as a liquid level sensor for a water tank. I posted this in Snippets because it isn't a complete solution, and it was only tested on a plastic gallon jug.
I cut out two aluminum foil strips, 25mm wide and the same length as the height of a plastic jug. They were taped to the outside of the jug, about six mm apart. One foil was connected to 0V of the test board, and one foil was connected to input C.2 of the PicAxe. Port B had each of it's eight pins connected to an LED in series with a 330 ohm resistor that was, in turn, connected to the +5 supply.
So, in summary, the only connections to the 18M2, besides the needed power supply, ground, and programming serial port connections, were a foil sensor on the jug, and eight LEDs. Quite simple.
Here's the code:
The first part of the routine is used to get the reading for a full jug. In my testing, I had the jug half full, and would tip it towards or away from the sensor foils to simulate a full jug, empty jug, or anywhere in between. So when the program starts, you have five seconds to tip the jug to indicate full, then another five seconds to tip the jub to empty. After that it starts lighting diodes to indicate the current level. Seems to work okay, but there are obvious improvements that could be made.Code:; USE TOUCH CONTROL FOR LIQUID LEVEL SENSING symbol maxrd = w1 ;tank full reading symbol minrd = w2 ;tank empty reading symbol del = w3 ;range from empty to full symbol level = w0 ;current sensor reading symbol test = w4 ;reading for each 1/8 tank symbol cntr = b12 ;counter for loop main: ; This portion requires tank to be full or tipped to cover sensor strips let dirsb = 255 ;set all port B pins for output let pinsb = 255 ;set all port B pins high to turn off LEDs pause 5000 ;pause to allow getting tank to full condition touch16 [%00010001], c.2, maxrd ;get a reading at tank full condition low b.0 ;blink that the reading has been taken pause 1000 high b.0 ;This portion requires tank to be empty or tipped to uncover sensor strips pause 5000 ;pause to allow getting tank to empty condition touch16 [%00010001], c.2, minrd ;get a reading at tank empty condition low b.0 ;blink that the reading has been taken pause 1000 high b.0 del = maxrd - minrd / 8 ;calculate difference in eighths of tank capacity ;Now in the working part of the program lupe: touch16 [%00010001], c.2, level ;get current reading for cntr = b.0 to b.7 ;light up leds to creat bar graph of current level test = cntr * del + minrd ;this test level for each 1/8 of a tank assumes linear ;relationship of level and depth of fluid. For some ;odd tank shapes, a different relationship could be ;found if level > test then low cntr ;if level is higher than a 1/8 tank increment, turn on led else high cntr endif next cntr goto lupe ;loop back to take a new reading end
I tweaked the setup of the touch command a little, but did not do extensive experimenting to see where it worked best. The whole setup is very sensitive to how wires are run, whether or not the computer is connected to the serial port, and what I was touching. In a real application, much of this would be fixed, but you will definitely need to calibrate after all is settled. EEPROM would be the place to store the calibration settings, but I didn't bother because this was just an academic exercise. (It's nice being retired)
I think that for tanks that are not of linear proportions, it might be possible to shape the tin foil strips to account for needing more capacitance or less, but this is another area that I did not explore. It might be easier to leave the electrodes linear, and experimentally obtain constants that could be tested against a current reading.
Have fun picaxing,
tom
) it is one superb piece of hardware
Bookmarks
