i am wondering if it is possible to get a picaxe to extract the time and date information from a NMEA serial data stream from a gps module.
the GGA - (Global Positioning System Fix Data) message is the one with all the info im interested in.
see page 7 of http://www.sparkfun.com/datasheets/GPS/Modules/SUP500F_v3.pdf for the structure of the sentance.
i need some ideas and help with the code so that it will output the time and date. (to send to an LCD)
can the picaxe do this fast enough as the GPS module sends the data at 10Hz?
am i correct that if i used the line
serin 1,N9600,(“$GPGGA,”),#b1
with the example sentence in the PDF that b1 would end up 111?
