Bit banging i2c on 08M
matherp
I want to use a 08M to do some very simple i2C communications. I found the attached code from Hippy which appears to do the job but can't get it to work. I'm trying to use it to read and write the memory on a DS1307 ($08-$37) so the only changes I've made are to set the correct slave address and limit the read/write address range. The DS1307 is mounted on a AXE091. I've proved the chip works fine using hi2c routines from a 28x2 on the same board. SCL is connected to pin 4 and SDA pin 1 as per the symbols in the routine and of course the axe091 has the pullups built in.
The problem is that the I2cStrobeScl routine never returns from the loop in which it waits for SCL to go high.
Any help would be gratefully received (particulalry Hippy!)
Thanks
Peter
#picaxe 08m
; *     I2C Master Test Program for the PICAXE-08M              MAST08-1.BAS  *
; *     This is an version of MAST18-1.BAS specifically designed to run on    *
; *     the PICAXE-08M using its bi-directional port abilities.               *
; *     The program will write to a series of adderesses and then read the    *
; *     values back.ad the address back ( the value should be what was sent   *
; *     The I2C code has been altered to only send a byte address, and the    *
; *     device address of the PICAXE-18X I2C Slave is $B0.                    *
;                              --.---.-- +V
;                               | | | | 2 x 4K7
;        PICAXE-08M             |_| |_|             PICAXE-18X
;        I2C MASTER              |   |              I2C SLAVE
;       |       X1 |-------------^---|-------------: O1       :
;       |       X4 |-----------------^-------------: O4       :
; *     Define the I2C device being used                                      *
        Symbol  I2C_ADDRESS     = %11010000     ; $D0 for DS1307
; *     Variables                                                             *
        Symbol  tstAdr          = b0
        Symbol  tstVal          = b1
        Symbol  i2cAdr          = w1    ' b3:b2
        Symbol  i2cAdrLsb       = b2
        Symbol  i2cAdrMsb       = b3
        Symbol  i2cVal          = b4
        Symbol  i2cDataByte     = b5
        Symbol  i2cAckBit       = b6
        Symbol  i2cBitCount     = b7
; *     Bit-Banged I/O definitions                                            *
        Symbol  SDA             = 1
        Symbol  SCL             = 4
        Symbol  SDA_PIN         = pin1
        Symbol  SCL_PIN         = pin4
; *     Main Program Code                                                     *
        ; Initialise the I2C comms
        Gosub InitI2cDevice
        ; Test I2C
        Do
          For i2cAdr = $08 To $3F
            Toggle 0
            i2cVal = i2cAdr ^ $80
            Gosub WriteI2cData
            Pause 1000
          Next
            Toggle 0
            Gosub ReadI2cData
            Pause 1000
          Next
        Loop
; *     High-Level I2C Interface Routines                                     *
WriteI2cData:
        Gosub I2cSendHeader
        i2cDataByte = i2cVal
        Gosub I2cSendByte
        Gosub InitI2cDevice
        Pause 20                        ; 20mS to allow write
        Return
ReadI2cData:
        Gosub I2cSendHeader
        Gosub I2cStart
        i2cDataByte = I2C_ADDRESS | $01
        Gosub I2cSendByte
        Input SDA                       ; SDA = 1 / Tri-State SDA
        For i2cBitCount = 0 To 7
          Gosub I2cStrobeScl
          i2cVal= i2cVal * 2 | i2cAckBit
        Next
InitI2cDevice:
        Low SCL                         ; SCL = 0
        Low SDA                         ; SDA = 0
        Input SCL                       ; SCL = 1
        Input SDA                       ; SDA = 1
        Return
; *     Low-Level I2C Interface                                               *
I2cSendHeader:
        Gosub I2cStart
        i2cDataByte = I2C_ADDRESS & $FE
        Gosub I2cSendByte
        i2cDataByte = i2cAdrLsb
I2cSendByte:
        For i2cBitCount = 0 TO 7
          If i2cDataByte < $80 Then
            Low SDA                     ; SDA = 0
          Else
            Input SDA                   ; SDA = 1
          End If
          Gosub I2cStrobeScl
          i2cDataByte = i2cDataByte * 2
        Next
        Gosub I2cStrobeScl
; ---   if i2cAckBit = 1 Then
; ---     SerTxd( "ACK FAILED",CR,LF )
; ---   end if
        Return
I2cStart:
        Input SDA                       ; SDA = 1
        Input SCL                       ; SCL = 1
        Low SDA                         ; SDA = 0
        Low SCL                         ; SCL = 0
        Return
I2cStrobeScl:
        Input SCL                       ; SCL = 1
        Do
        Loop Until SCL_PIN = 1
        i2cAckBit = SDA_PIN
        Low SCL                         ; SCL = 0
        Return
; *     End of program                                                        *
matherp
OK solved
I win moron of the week award.
When the code says pin 1 it means I/O pin 1 (i.e. pin 6) not physical pin 1, same for pin 4
Hippy - thanks for the code snippet - now I just need to mod it to read and write multiple bytes in one go
Best regards
Peter
Study
I2cSendHeader:
And you will see it is already sending two bytes back to back - (slave then data)
once with Gosub I2cSendByte and then by 'falling into' I2cSendByte again.
You can expand this to three or more bytes by just adding more
Gosub I2cSendByte
matherp
Yes got that bit. Then to read two bytes I need to send an ACK after the first byte read to get the next byte.
Low SDA
Gosub I2cStrobeScl
input SDA
seems to work
Thanks
Peter
Yes, just us an 'ack' (low SDA) when you want another byte and a 'nack' (input SDA) to finish.
newplumber
Hi
I was playing around with the code and for me it seems very complicated ...out of my league
If I use this code I seem to get no response from the sertxd so something is out of whack
#picaxe 20X2
'#NO_DATA
#terminal 9600
; *     Variables                                                             *
        Symbol  tstAdr          = b0
        Symbol  tstVal          = b1
        Symbol  i2cVal          = b4
        Symbol  SDA             = B.1
        Symbol  SCL             = B.0
        Symbol  SDA_PIN         = pinB.1
        Symbol  SCL_PIN         = pinB.0
        Gosub InitI2cDevice
; Test I2C
       Do
            Toggle 0
            Gosub WriteI2cData
            Pause 1000
          Next
            Toggle 0
            Gosub ReadI2cData
            Pause 2000
		sertxd ("____START_____",cr,lf)	  ' added code to see what values show
		sertxd ("tstAdr = ",#tstAdr,cr,lf)
		sertxd ("tstVal = ",#tstVal,cr,lf)
		sertxd ("i2cAdr  = ",#i2cAdr ,cr,lf)
		sertxd ("i2cAdrLsb = ",#i2cAdrLsb,cr,lf)
		sertxd ("i2cAdrMsb = ",#i2cAdrMsb,cr,lf)
		sertxd ("i2cVal = ",#i2cVal,cr,lf)
		sertxd ("i2cDataByte = ",#i2cDataByte,cr,lf)
		sertxd ("i2cAckBit = ",#i2cAckBit,cr,lf)
		sertxd ("i2cBitCount = ",#i2cBitCount,cr,lf)
		sertxd ("____END_____",cr,lf)
           Next
         Loop
WriteI2cData:
        Gosub I2cSendHeader
        Gosub I2cSendByte
        Gosub InitI2cDevice
        Return
ReadI2cData:
        Gosub I2cSendHeader
        Gosub I2cStart
        Gosub I2cSendByte
          Gosub I2cStrobeScl
        Next
InitI2cDevice:
        Low SCL                         ; SCL = 0
        Low SDA                         ; SDA = 0
        Input SCL                       ; SCL = 1
        Input SDA                       ; SDA = 1
        Return
I2cSendHeader:
        Gosub I2cStart
        Gosub I2cSendByte
I2cSendByte:
            Low SDA                     ; SDA = 0
          Else
            Input SDA                   ; SDA = 1
          End If
          Gosub I2cStrobeScl
        Next
        Gosub I2cStrobeScl
; ---   end if
        Return
I2cStart:
        Input SDA                       ; SDA = 1
        Input SCL                       ; SCL = 1
        Low SDA                         ; SDA = 0
        Low SCL                         ; SCL = 0
        Return
I2cStrobeScl:
        Input SCL                       ; SCL = 1
        Do
        i2cAckBit = SDA_PIN
        Low SCL                         ; SCL = 0
        Return
Its like the program just ends before sertxding and I don't see where that's at
EDIT: I do finally get it to show setxd but the values seem in the fog
newplumber
Hi
I finally won at the code thanks to hippys example
the part that i missed ...big mistake was
so I had to change the address to $00-$06 instead of ($08-$37)
but here is the working code if a person is just going to read the time from a DS3231 RTC
#picaxe 20X2
'#NO_DATA
#terminal 38400
setfreq m32
; *     Variables                                                             *
        Symbol  tstAdr          = b0
        Symbol  tstVal          = b1
        Symbol  i2cVal          = b4
        Symbol  Index	        = b8
	  SYMBOL  hours           = b9
        SYMBOL  mins            = b10
        SYMBOL  secs            = b11
        SYMBOL  day             = b12     ' not used
        SYMBOL  date            = b13
        SYMBOL  month           = b14
        SYMBOL  year            = b15
#Define BcdToDec(bcd) bcd / $10 * 250 + bcd
        Symbol  SDA             = B.1
        Symbol  SCL             = B.0
        Gosub InitI2cDevice
; Test I2C
       Do
           i2cAdr = $00
  		'Toggle 0
            Gosub ReadI2cData
		  secs = i2cVal
           i2cAdr = $01
  		'Toggle 0
            Gosub ReadI2cData
		  mins = i2cVal
           i2cAdr = $02
  		'Toggle 0
            Gosub ReadI2cData
		  hours = i2cVal
           i2cAdr = $03
  		'Toggle 0
            Gosub ReadI2cData
		  day = i2cVal
            i2cAdr = $04
  		'Toggle 0
            Gosub ReadI2cData
		  date = i2cVal
           i2cAdr = $05
  		'Toggle 0
            Gosub ReadI2cData
		  month = i2cVal
            i2cAdr = $06
  		'Toggle 0
            Gosub ReadI2cData
		  year = i2cVal
  secs  = BcdToDec( secs  )
  mins  = BcdToDec( mins  )
  hours = BcdToDec( hours )
  date  = BcdToDec( date  )
  month = BcdToDec( month )
  year  = BcdToDec( year  )
 sertxd ("----Start----",cr,lf)
 sertxd ("secs = ",#secs,cr,lf)
 sertxd ("mins = ",#mins,cr,lf)
 sertxd ("hours = ",#hours,cr,lf)
 sertxd ("day = ",#day,cr,lf)
 sertxd ("date = ",#date,cr,lf)
 sertxd ("month = ",#month,cr,lf)
 sertxd ("year = ",#year,cr,lf)
 sertxd ("----End----",cr,lf)
pause 2000
         Loop
ReadI2cData:
        Gosub I2cSendHeader
        Gosub I2cStart
        Gosub I2cSendByte
          Gosub I2cStrobeScl
        Next
InitI2cDevice:
        Low SCL                         ; SCL = 0
        Low SDA                         ; SDA = 0
        Input SCL                       ; SCL = 1
        Input SDA                       ; SDA = 1
        Return
I2cSendHeader:
        Gosub I2cStart
        Gosub I2cSendByte
I2cSendByte:
            Low SDA                     ; SDA = 0
          Else
            Input SDA                   ; SDA = 1
          End If
          Gosub I2cStrobeScl
        Next
        Gosub I2cStrobeScl
        Return
I2cStart:
        Input SDA                       ; SDA = 1
        Input SCL                       ; SCL = 1
        Low SDA                         ; SDA = 0
        Low SCL                         ; SCL = 0
        Return
I2cStrobeScl:
        Input SCL                       ; SCL = 1
        Do
        i2cAckBit = SDA_PIN
        Low SCL                         ; SCL = 0
        Return
It is better to modify the code so it reads the complete RTC data in one read packet. If reading a byte at a time there is a chance that, after one value is read, it increments, rolls over and increments the next value up before that is read.
For example; at "00:59" you read the minutes (59), there's a clock tick and at "01:00" you read the hour (01), which gives an apparent time of "01:59" which is not correct.
An alternative is to re-read the least significant data and check it is the same as originally read; if not there has been a tick behind the scene and a re-read of all the data should resolve that.
newplumber
thanks hippy, I understand what you simply explained , but I guess I need alot more time to see how that can be done
and its a good point. I'll keep trying different ways
newplumber
This is the only way I could think of reading in one packet
Main:
 gosub Read_Time
 sertxd ("b9=secs = ",#secs,cr,lf)
 sertxd ("b10=mins = ",#mins,cr,lf)
 sertxd ("b11=hours = ",#hours,cr,lf)
 sertxd ("b12=day = ",#day,cr,lf)
 sertxd ("b13=date = ",#date,cr,lf)
 sertxd ("b14=month = ",#month,cr,lf)
 sertxd ("b15=year = ",#year,cr,lf)
  pause 10000
Goto Main
Read_Time: Bptr = 9
For i2cAdr = $00 to $06
        Gosub I2cSendHeader
        Gosub I2cStart
        Gosub I2cSendByte
          Gosub I2cStrobeScl
        Next
  @bptrinc = i2cVal
InitI2cDevice:
        Low SCL                         ; SCL = 0
        Low SDA                         ; SDA = 0
        Input SCL                       ; SCL = 1
        Input SDA                       ; SDA = 1
Next
        Return
Theres probably a better way ..but its all I can think of right now
That is still reading each byte at a time. You need to perform a single multi-byte read rather than multiple single byte reads.
There may be an example of bit-banged multi-byte read on the forum or you will have to look at the I2C specification and follow the sequence of start and stop bits, sending and reading bytes. The existing code can be used as a basis but needs to be changed.
newplumber
Now that is going over my head...although I will try but I am getting confused (sadly don't take much)
          Gosub I2cStrobeScl
        Next
because each byte needs to have 0 to 7 in order to read during a specific time
I am learning tho ....well.....tiny bit
AllyCat
I think the aim is to send only one start sequence (and Slave address) and then read all 7 bytes quickly in sequence. That probably needs the For i2cAdr = $00 to $06 to be moved to immediately before the For i2cBitCount = 0 To 7 (but you may need to initaialise.i2cAdr in the original position for the unshown subroutine to work correctly). The corresponding next then needs to be located at least after the @bptrinc = i2cVal , but I'm not sure how much further down.... The program appears to "fall into" the InitI2cDevice: routine , which is a "trick" I often use myself,, but I do usually include a comment that it's supposed to happen. ;)
However, I think we can assume that the fall through is intended to happen because the code is very similar to that suggested by Technical in post #2 of this thread. As you may see from that thread, my preference was to use the hardware I2C and find an "alternative" solution to a pin conflict, so I've never actually tried that code.
newplumber
Thanks Allycat
I am breaking down the code bit by bit so I can try to understand correctly ...
I will do some tests on how that might be done
newplumber
While I am doing my slow homework and studying the DS3231 datasheet I found here
https://www.openimpulse.com/blog/wp-content/uploads/wpsc/downloadables/DS3231-I2C-Real-Time-Clock-Datasheet.pdf
I thought this might be interesting ..if I am reading it right ...on page 11 it states
Figure 1 shows the address map for the DS3231 timekeeping
registers. During a multibyte access, when the
address pointer reaches the end of the register space
(12h), it wraps around to location 00h. On an I2C
START or address pointer incrementing to location 00h,
the current time is transferred to a second set of registers.
The time information is read from these secondary
registers, while the clock may continue to run. This
eliminates the need to reread the registers in case the
main registers update during a read.
Of course I still have to get the code to read a single multi-byte read...but thought maybe
its impossible to get a misreading when the DS3231 updates ...its just my thought
or do I have the page upside down :)
UPDATE:
I made the code line by line (with no gosubs) to make it easier to follow
and 8hrs later I'm still missing something...I know it can be done ...but I have to understand a whole lot more
btw
            Low SDA                     ; SDA = 0
          Else
            Input SDA                   ; SDA = 1
          End If
          Gosub I2cStrobeScl
        Next
is pure genius
newplumber
Hi
on page 15 on the DS3231 data sheet (post #16)
in the bottom right hand corner
it states
Acknowledge: Each receiving device, when
addressed, is obliged to generate an acknowledge
after the reception of each byte. The master device
must generate an extra clock pulse, which is associated
with this acknowledge bit.
but the code is working as
Acknowledging each BIT this is where i am frooze up
because if I use
[color=Black]I2C_Send_Byte:
   [/color][color=Blue]For [/color][color=Purple]i2cBitCount [/color][color=DarkCyan]= [/color][color=Navy]0 [/color][color=Blue]TO [/color][color=Navy]7
       [/color][color=Blue]If [/color][color=Purple]i2cDataByte [/color][color=DarkCyan]< [/color][color=Navy]$80 [/color][color=Blue]Then
        Low SDA                     [/color][color=Green]; SDA = 0
       [/color][color=Blue]Else
        Input SDA                   [/color][color=Green]; SDA = 1
      [/color][color=Blue]End If
            Input SCL                       [/color][color=Green]; SCL = 1
             [/color][color=Blue]Do
             Loop Until [/color][color=Purple]SCL_PIN [/color][color=DarkCyan]= [/color][color=Navy]1
        [/color][color=Purple]i2cAckBit [/color][color=DarkCyan]= [/color][color=Purple]SDA_PIN
            [/color][color=Blue]Low SCL                         [/color][color=Green]; SCL = 0
     [/color][color=Purple]i2cDataByte [/color][color=DarkCyan]= [/color][color=Purple]i2cDataByte [/color][color=DarkCyan]* [/color][color=Navy]2
   [/color][color=Blue]Next
    Input SDA
Return[/color]
it seems to me its acknowledging each bit
if I use ...
That's sending each of the 8 data bits but it's not reading the ACK after those 8 bits. At the end you need to make SDA an input so it floats high, then clock out an SCL pulse.
The full sequence to read the data should be similar to this, untested -
                        Gosub SendStartBit
i2cDataByte = $D0 | 0 : Gosub SendByteAndReadAck                      ; Write to device $D0
i2cDataByte = $00     : Gosub SendByteAndReadAck                      ; Set address to $00
                        Gosub SendStopBit
                        Gosub SendStartBit
i2cDataByte = $D0 | 1 : Gosub SendByteAndReadAck                      ; Read from device $D0
                        Gosub ReadByteAndSendAck : secs = i2cDataByte ; Read location $00
                        Gosub ReadByteAndSendAck : year = i2cDataByte ; Read location $06
                        Gosub SendStopBit
SendByteAndReadAck:
      Low SDA                                ; SDA = 0
    Else
      Input SDA                              ; SDA = 1
    End If
    Input SCL                                ; SCL = 1
    Do : Loop Until SCL_PIN = 1
    Low SCL                                  ; SCL = 0
  Next
  Input SDA
  Input SCL                                  ; SCL = 1
  i2cAckBit = SDA_PIN
  Low SCL                                    ; SCL = 0
  Return
ReadByteAndSendAck:
  Input SDA
    Input SCL                                ; SCL = 1
    i2cDataByte = i2cDataByte * 2 | SDA_PIN
    Low SCL                                  ; SCL = 0
  Next
  Input SCL                                  ; SCL = 1
  Low SCL                                    ; SCL = 0
  Return
newplumber
Thanks Hippy ...I will look into that example ....you might of saved me 2 weeks
I see/read how the sequence is to send/receive to the DS3231 but how to send bytes from M(master) to S (slave) is confusing for me
so in a example your do/loop until
SendByteAndReadAck:
      Low SDA                                ; SDA = 0
    Else
      Input SDA                              ; SDA = 1
    End If
    Input SCL                                ; SCL = 1
[SIZE=4]    Do : Loop Until SCL_PIN = 1[/SIZE]
For me it means its (do/loop) waiting for the DS3231 to send SCL high and that means its ready for the next bit?
but it is not the end of the "byte" "acknowledge bit" as shown in the data sheet? ...hopefully I make sense
newplumber
Its a sweet example Hippy ...but for some reason its stuck on reading seconds only like showing
"terminal"
start sertxd
b9=secs = 23
b10=mins = 165
b11=hours = 165
b12=day = 255
b13=date = 165
b14=month = 165
b15=year = 165
end sertxd
start sertxd
b9=secs = 26
b10=mins = 165
b11=hours = 165
b12=day = 255
b13=date = 165
b14=month = 165
b15=year = 165
end sertxd
Main:
				    Gosub I2C_Start
i2cDataByte = I2C_ADR | 0 : Gosub SendByteAndReadAck                      ; Write to device $D0
                            Gosub I2C_Stop
                            Gosub I2C_Start
i2cDataByte = I2C_ADR | 1 : Gosub SendByteAndReadAck                      ; Read from device $D0
                            Gosub ReadByteAndSendAck : mins   = i2cDataByte ; Read location $01
				    Gosub ReadByteAndSendAck : hours  = i2cDataByte ; Read location $02
				    Gosub ReadByteAndSendAck : day    = i2cDataByte ; Read location $03
				    Gosub ReadByteAndSendAck : date   = i2cDataByte ; Read location $04
				    Gosub ReadByteAndSendAck : month  = i2cDataByte ; Read location $05
                            Gosub I2C_Stop
			          gosub Sertxd_Time                       'sertxd out all 6 bytes of data recieved by ds3231
Goto Main
Its been this kind of problem 36 hrs ago ...and my simple brain can only read it with resending the data address
which in turn is not a single multi-byte read ...maybe i am missing the Ack after the
Main:
				    Gosub I2C_Start
                            Gosub I2C_Stop
                            Gosub I2C_Start
                            Gosub I2C_Stop
                            Gosub I2C_Start
                            Gosub ReadByteAndSendAck : mins  = i2cDataByte ; Read location $00
                            Gosub I2C_Stop
Goto Main
But always I am having fun learning how the bits are biting
newplumber
Another mystery to my puzzle is if I use this code
Main:
Bptr = 9
				    Gosub I2C_Start
for b1 = 0 to 6
[COLOR="#FF0000"]i2cDataByte = $00[/COLOR]         : Gosub SendByteAndReadAck                      ; Set address to $00
                            Gosub I2C_Stop
                            Gosub I2C_Start
                            Gosub ReadByteAndSendAck : @bptrinc = i2cDataByte ; Read location $00
next b1
                            Gosub I2C_Stop
Goto Main
it shows the date,time perfectly
so it is running thru $00 to $06 with out changing the
"i2cDataByte = $00"
Post #21 works because the chip supports address auto-incrementing. But, with additional stops then starts you are back to reading multiple single bytes not one multiple byte read.
That is to allow the I2C device to do clock-stretching. The device may hold SCL low until it is ready even if the master has let SCL go high. It waits until the device tells the master it can proceed.
newplumber
Well thanks again
I don't mind it not being my friend since I truly don't really understand whats happening
but i am understanding a ton more with all your/Allycats help
and someday I wish to succeed in the "one multiple byte read".
This the closest I have been able to get to
[color=Black]Main:                   [/color]
[color=Purple]Bptr [/color][color=DarkCyan]= [/color][color=Navy]9
                            [/color][color=Blue]Gosub [/color][color=Black]I2C_Start[/color]
[color=Purple]i2cDataByte [/color][color=DarkCyan]= [/color][color=Blue]I2C_ADR [/color][color=Black]| [/color][color=Navy]0 [/color][color=Black]: [/color][color=Blue]Gosub [/color][color=Black]SendByteAndReadAck                      [/color][color=Green]; Write to device $D0[/color]
[color=Purple]i2cDataByte [/color][color=DarkCyan]= [/color][color=Navy]$00         [/color][color=Black]: [/color][color=Blue]Gosub [/color][color=Black]SendByteAndReadAck                      [/color][color=Green]; Set address to $00
                            [/color][color=Blue]Gosub [/color][color=Black]I2C_Stop
                            [/color]
[color=Blue]for [/color][color=Purple]b1 [/color][color=DarkCyan]= [/color][color=Navy]0 [/color][color=Blue]to [/color][color=Navy]6
                            [/color][color=Blue]Gosub [/color][color=Black]I2C_Start                           [/color]
[color=Purple]i2cDataByte [/color][color=DarkCyan]= [/color][color=Blue]I2C_ADR [/color][color=Black]| [/color][color=Navy]1 [/color][color=Black]: [/color][color=Blue]Gosub [/color][color=Black]SendByteAndReadAck                      [/color][color=Green]; Read from device $D0
                            [/color][color=Blue]Gosub [/color][color=Black]ReadByteAndSendAck : [/color][color=Purple]@bptrinc [/color][color=DarkCyan]= [/color][color=Purple]i2cDataByte [/color][color=Green]; Read location $00[/color]
[color=Blue]next [/color][color=Purple]b1
                            [/color][color=Blue]gosub [/color][color=Black]Sertxd_Time                       [/color][color=Green]'sertxd out all 6 bytes of data recieved by ds3231                  [/color]
[color=Blue]Goto [/color][color=Black]Main [/color]
I think I made a mistake in the 'ReadByteAndSendAck' routine. I was leaving SDA high when issuing the supposed ACK which therefore presents itself as a NAK. It probably should be -
ReadByteAndSendAck:
  Input SDA
    Input SCL                                ; SCL = 1
    Low SCL                                  ; SCL = 0
  Next
  [b]Low SDA                                    ; SDA = 0[/b]
  Input SCL                                  ; SCL = 1
  Low SCL                                    ; SCL = 0
  [b]Input SDA[/b]
  Return
newplumber
Thanks again hippy ...its getting closer
okay now I am getting a "one liner multi byte read" ...but I still need to figure out why the terminal
shows the correct time/date in every other sertxd...... even tho its data address is $00
but its good to know its reading the one liner.
"terminal"
----Start----
b9=secs = 39 ' 39 secs
b10=mins = 27 '27 mins
b11=hours = 0 ' 0 hours I restarted it so many times
b12=day = 1
b13=date = 1
b14=month = 1
b15=year = 0
----End----
----Start----
b9=secs = 15
b10=mins = 165
b11=hours = 165
b12=day = 255
b13=date = 165
b14=month = 165
b15=year = 165
----End----
----Start----
b9=secs = 41 ' 41 secs
b12=day = 1
b13=date = 1
b14=month = 1
b15=year = 0
----End----
newplumber
Okay here is the code I've been trying to produce of course 99% of it is from thanks to Hippy
After reading more in the DS3231 data sheet...it says on the last byte to read don't include a Ack bit
So after changing that ... it now reads beautiful every time.
 'I2C bit_banged to read the DS3231 RTC
#picaxe 20X2
'#NO_DATA
#terminal 38400
setfreq m32
        Symbol  i2cVal          = b4
        SYMBOL  secs            = b9
        SYMBOL  mins            = b10
        SYMBOL  hours           = b11
        SYMBOL  date            = b13
        SYMBOL  month           = b14
        SYMBOL  year            = b15
  Symbol  I2C_ADR     = %11010000     ; Slave Address for DS3231
        Symbol  SDA             = B.1
        Symbol  SCL             = B.0
pause 8000
Power_Reset:
Gosub I2C_Stop
Main: '==========================Main Program====================================================
Bptr = 9
    Gosub I2C_Start
i2cDataByte = I2C_ADR | 0 : Gosub SendByteAndReadAck                        ; Write to slave device $D0
                            Gosub I2C_Start
i2cDataByte = I2C_ADR | 1 : Gosub SendByteAndReadAck                        ; Read from slave device $DS
for b1 = 0 to 5
                            @bptrinc = i2cDataByte                          ; Read location $00-$05
next b1
                            Gosub ReadByteAndSendNOAck
                            @bptrinc = i2cDataByte                          ; Read location $06 with out a Ack
                            Gosub I2C_Stop
Goto Main
Sertxd_Time:
  pause 8000
Return
SendByteAndReadAck:
      Low SDA                                ; SDA = 0
    Else
      Input SDA                              ; SDA = 1
    End If
    Input SCL                                ; SCL = 1
    Low SCL                                  ; SCL = 0
  Next
  Input SDA
  Input SCL                                  ; SCL = 1
  i2cAckBit = SDA_PIN
  Low SCL                                    ; SCL = 0
 Return
 ReadByteAndSendAck:
  Input SDA
    Input SCL                                ; SCL = 1
    Low SCL                                  ; SCL = 0
  Next
  Low SDA                                    ; SDA = 0
  Input SCL                                  ; SCL = 1
  Low SCL                                    ; SCL = 0
  Input SDA
 Return
 ReadByteAndSendNOAck: 'after receiveing last byte it needs a no acknowledge bit
  Input SDA
    Input SCL                                ; SCL = 1
    Low SCL                                  ; SCL = 0
  Next
 Return
I2C_Start:
;START a data transfer: A change in the state of the
;data line from high to low, while the clock line is high,
;defines a START condition.
                   Input SCL                       ; SCL = 1
                   Input SDA                       ; SDA = 1
                   Low SDA                         ; SDA = 0
                   Low SCL                         ; SCL = 0
Return
I2C_Stop:
;STOP a data transfer: A change in the state of the
;data line from low to high, while the clock line is high,
;defines a STOP condition.
              Low SDA                         ; SDA = 0
              Input SCL                       ; SCL = 1
              Input SDA                       ; SDA = 1
              Low SCL                         ; SCL = 0
Return
FWIW... It feels I'm probably past the 100,000 download warranty :)...while studying this code
but I did learn some valuable lessons
You will probably find that it actually says send "Not ACK" (NAK/NACK) rather than "No ACK".
You currently aren't sending either, neither ACK nor NAK. It seesm to work but it is probably best to make the last "ReadByteSendNak" -
ReadByteAndSendNak:
  Input SDA
    Input SCL                                ; SCL = 1
    Low SCL                                  ; SCL = 0
  Next
  Input SCL                                  ; SCL = 1
  Low SCL                                    ; SCL = 0
  Return
It has been a while since I have done bit-banged I2C and I wasn't sure if the last byte of a read should be ACK'd or NAK'd. My reading of the I2C spec is it should be an ACK but, either way, it shouldn't matter with a STOP and then a subsequent START, an explicit write which sets the read address before the next read, but it seems it does, at least here.
My preference is not to use '@bptr' to store data which is read. I am not sure why that started getting used but would guess it was an attempt to save program memory which it does. I don't believe it is worth it when there is no shortage of program memory. It just makes things more complicated and introduces the potential for problems for others using the code and modifying that.
If one is going to do that it makes sense to move '@bptrinc=i2cDataByte' into the actual 'ReadByte' routines to save program memory, and also change that to '@bptrinc=BcdToBin(i2cDataByte)', to save having to do the BCD to binary conversion later. One should probably take the byte reading part out of the two 'ReadByte' routines so there is just one set of common code to call to do that if saving program memory is the goal.
I2C_Stop:
              Low SDA                         ; SDA = 0
              Input SCL                       ; SCL = 1
              Input SDA                       ; SDA = 1
              Low SCL                         ; SCL = 0
Return
That's not right. After the STOP both SDA and SCL should be left high, made inputs. That could be why the chip wasn't handling the STOP and START as expected when the last byte read had an ACK rather than NAK.
I believe it should be -
I2C_Stop:
              Low   SCL                       ; SCL = 0
              Low   SDA                       ; SDA = 0
              Input SCL                       ; SCL = 1
              Input SDA                       ; SDA = 1
Return
newplumber
It Started When I was testing a million different ways ...it (@bptr) was easier then to copy/paste different trial/error code before the "multi byte liner" was invented,
and your correct I will look over the code and make the changes so its in the simplest form
Yes I should have known ...since we use 4k7 ohm pullups .
newplumber
Hi
After testing,retesting,reading,rereading here is I2C bit-banged version AA
 'I2C bit_banged to read(only) time from the DS3231 RTC  Version AA
#picaxe 20X2
#NO_DATA
#terminal 38400
setfreq m32
  [color=Blue]Symbol  [/color][color=Purple]i2cDataByte     [/color][color=DarkCyan]= [/color][color=Purple]b6     [/color][color=Green]' send/read byte
  [/color][color=Blue]Symbol  [/color][color=Purple]i2cBitCount     [/color][color=DarkCyan]= [/color][color=Purple]b7     [/color][color=Green]' loop for byte data (8)bits
  [/color][color=Blue]SYMBOL  [/color][color=Purple]secs            [/color][color=DarkCyan]= [/color][color=Purple]b8     [/color][color=Green]' $00-$59
  [/color][color=Blue]SYMBOL  [/color][color=Purple]mins            [/color][color=DarkCyan]= [/color][color=Purple]b9     [/color][color=Green]' $00-$59
  [/color][color=Blue]SYMBOL  [/color][color=Purple]hours           [/color][color=DarkCyan]= [/color][color=Purple]b10    [/color][color=Green]' $00-$23
  [/color][color=Blue]SYMBOL  [/color][color=Purple]day             [/color][color=DarkCyan]= [/color][color=Purple]b11    [/color][color=Green]' $01-$07
  [/color][color=Blue]SYMBOL  [/color][color=Purple]date            [/color][color=DarkCyan]= [/color][color=Purple]b12    [/color][color=Green]' $01-$31
  [/color][color=Blue]SYMBOL  [/color][color=Purple]month           [/color][color=DarkCyan]= [/color][color=Purple]b13    [/color][color=Green]' $01-$12
  [/color][color=Blue]SYMBOL  [/color][color=Purple]year            [/color][color=DarkCyan]= [/color][color=Purple]b14    [/color][color=Green]' $00-$99
  [/color][color=Blue]Symbol  SCL             [/color][color=DarkCyan]= [/color][color=Blue]B.0    [/color][color=Green]' picaxe-B.0 to DS3231-SCL  with 4k7-ohm pullup resistor (+5vdc)
  [/color][color=Blue]Symbol  SDA             [/color][color=DarkCyan]= [/color][color=Blue]B.1    [/color][color=Green]' picaxe-B.1 to DS3231-SDA  with 4k7-ohm pullup resistor (+5vdc)
  [/color][color=Blue]Symbol  [/color][color=Purple]SCL_PIN         [/color][color=DarkCyan]= [/color][color=Purple]pinB.0
  [/color][color=Blue]Symbol  [/color][color=Purple]SDA_PIN         [/color][color=DarkCyan]= [/color][color=Purple]pinB.1 [/color]
  Symbol  I2C_ADR     = %11010000             ;Slave Address for DS3231
[color=Navy]#Define [/color][color=Black]BcdToDec[/color][color=Blue]([/color][color=Black]bcd[/color][color=Blue]) [/color][color=Black]bcd [/color][color=DarkCyan]/ [/color][color=Navy]$10 [/color][color=DarkCyan]* [/color][color=Navy]250 [/color][color=DarkCyan]+ [/color][color=Black]bcd   [/color][color=Green];switch bcd to decimal
 [/color]
[color=Black]Power_Reset:
Main: [/color][color=Green]'==========================Main Program====================================================
[color=Purple]i2cDataByte [/color][color=DarkCyan]= [/color][color=Blue]I2C_ADR [/color][color=Black]| [/color][color=Navy]0 [/color][color=Black]: [/color][color=Blue]Gosub [/color][color=Black]SendByteAndReadAck                       [/color][color=Green]; Write to slave device $D0[/color]
[color=Purple]i2cDataByte [/color][color=DarkCyan]= [/color][color=Blue]I2C_ADR [/color][color=Black]| [/color][color=Navy]1 [/color][color=Black]: [/color][color=Blue]Gosub [/color][color=Black]SendByteAndReadAck                       [/color][color=Green]; Read from slave device $D1
                            [/color][color=Blue]Gosub [/color][color=Black]ReadByteAndSendAck :[/color][color=Purple]secs  [/color][color=DarkCyan]= [/color][color=Purple]i2cDataByte  [/color][color=Green]; Data Address $00
                            [/color][color=Blue]Gosub [/color][color=Black]ReadByteAndSendAck :[/color][color=Purple]mins  [/color][color=DarkCyan]= [/color][color=Purple]i2cDataByte  [/color][color=Green]; Data Address $01
                            [/color][color=Blue]Gosub [/color][color=Black]ReadByteAndSendAck :[/color][color=Purple]hours [/color][color=DarkCyan]= [/color][color=Purple]i2cDataByte  [/color][color=Green]; Data Address $02
                            [/color][color=Blue]Gosub [/color][color=Black]ReadByteAndSendAck :[/color][color=Purple]day   [/color][color=DarkCyan]= [/color][color=Purple]i2cDataByte  [/color][color=Green]; Data Address $03
                            [/color][color=Blue]Gosub [/color][color=Black]ReadByteAndSendAck :[/color][color=Purple]date  [/color][color=DarkCyan]= [/color][color=Purple]i2cDataByte  [/color][color=Green]; Data Address $04
                            [/color][color=Blue]Gosub [/color][color=Black]ReadByteAndSendAck :[/color][color=Purple]month [/color][color=DarkCyan]= [/color][color=Purple]i2cDataByte  [/color][color=Green]; Data Address $05
                            [/color][color=Blue]Gosub [/color][color=Black]ReadByteAndSendNAk :[/color][color=Purple]year  [/color][color=DarkCyan]= [/color][color=Purple]i2cDataByte  [/color][color=Green]; Data Address $06 (last byte read)
                            [/color][color=Blue]Gosub [/color][color=Black]Sertxd_Time     [/color][color=Green]'sertxd out all 6 bytes of time/date     [/color]
Sertxd_Time:
 day    = BcdToDec( day   )
 [color=Blue] sertxd ([/color][color=Red]"----Start----"[/color][color=Black],  [/color][color=Blue]cr[/color][color=Black],[/color][color=Blue]lf)
  sertxd ([/color][color=Red]"secs  = "[/color][color=Black],#[/color][color=Purple]secs[/color][color=Black], [/color][color=Blue]cr[/color][color=Black],[/color][color=Blue]lf)
  sertxd ([/color][color=Red]"mins  = "[/color][color=Black],#[/color][color=Purple]mins[/color][color=Black], [/color][color=Blue]cr[/color][color=Black],[/color][color=Blue]lf)
  sertxd ([/color][color=Red]"hours = "[/color][color=Black],#[/color][color=Purple]hours[/color][color=Black],[/color][color=Blue]cr[/color][color=Black],[/color][color=Blue]lf)
  sertxd ([/color][color=Red]"day   = "[/color][color=Black],#[/color][color=Purple]day[/color][color=Black],  [/color][color=Blue]cr[/color][color=Black],[/color][color=Blue]lf)
  sertxd ([/color][color=Red]"date  = "[/color][color=Black],#[/color][color=Purple]date[/color][color=Black], [/color][color=Blue]cr[/color][color=Black],[/color][color=Blue]lf)
  sertxd ([/color][color=Red]"month = "[/color][color=Black],#[/color][color=Purple]month[/color][color=Black],[/color][color=Blue]cr[/color][color=Black],[/color][color=Blue]lf)
  sertxd ([/color][color=Red]"year  = "[/color][color=Black],#[/color][color=Purple]year[/color][color=Black], [/color][color=Blue]cr[/color][color=Black],[/color][color=Blue]lf)
  sertxd ([/color][color=Red]"-----End------"[/color][color=Black], [/color][color=Blue]cr[/color][color=Black],[/color][color=Blue]lf)
  pause [/color][color=Navy]8000   [/color]
[color=Blue]Return [/color]
SendByteAndReadAck:   ' sending slave/data addresses to the DS3231
      Low SDA                                ; SDA = 0
    Else
      Input SDA                              ; SDA = 1
    End If
    Input SCL                                ; SCL = 1
    Low SCL                                  ; SCL = 0
  Next
  Input SDA
  Input SCL                                  ; SCL = 1
  Low SCL                                    ; SCL = 0
Return
ReadByteAndSendAck: ' reading data bytes from the DS3231
  Input SDA
    Input SCL                                ; SCL = 1
    Low SCL                                  ; SCL = 0
  Next
  Low SDA                                    ; SDA = 0
  Input SCL                                  ; SCL = 1
  Low SCL                                    ; SCL = 0
  Input SDA                                  ; SDA = 1
Return
ReadByteAndSendNak: ' reading last data byte from the DS3231
  Input SDA                                  ; SDA = 1
    Input SCL                                ; SCL = 1
    Low SCL                                  ; SCL = 0
  Next
  Input SCL                                  ; SCL = 1
  Low SCL                                    ; SCL = 0
Return
I2C_Start:
              Input SCL                       ; SCL = 1
              Input SDA                       ; SDA = 1
              Low SDA                         ; SDA = 0
              Low SCL                         ; SCL = 0
Return
I2C_Stop:
              Low SCL                         ; SCL = 0
              Low SDA                         ; SDA = 0
              Input SCL                       ; SCL = 1
              Input SDA                       ; SDA = 1
Return
