sierrasmith71
I have designed a model railroad turntable controller using a 28X2 and a stepper motor. The user interface uses a 4 x 20 serial LCD, a 4 bit BCD rotary encoder - to select the track and end to be moved- two push button monentary switches and a two postion toggle switch.
I keep getting diverted --more functions or different motor drive and it is not finished yet. This past Friday I began wondering how I could use a model railroad DCC system to contol the turntable? This requires that the Picaxe reads the DCC commands from the tracks or command bus. Looking into this lead me to conclude this is not possible (directly) with the Picaxe as it is much to slow to process DCC commands on the fly. Well, what to do?
I had a flash of inspiration --" Since the motor drive output of a locomotive DCC decode is a PWM constant voltage, why not try to read the width of these pulses with a pulsin command? " If successful I could use the motor speed "steps" for track selection data for my controller and use the selectable DCC function outputs as inputs to replace the present switches.
After the required messing about and research I was able to successfully read and decode DCC 28 speed steps with the 28X2.
(This is using a loco DCC decoder as a stationary decoder --no motor is connected. )
The red and black wires are connected to the DCC tracks or bus.
I connected the orange (Motor+) and the grey (Motor-) with a 10K resistor, and a 33k res. from the orange (motor+) to pin c.0 on the Picaxe. The voltage of the pulse is about 13.5 volts and after searching the forums and the PIC reference info I concluded that it was safe to do it this way.
I used the following code to read the data and display it as a track # . There is a one to one relationship between the loco speed shown on the DCC system and what the LCD displays as Track #... Sweet.
I used an inexpensive Bachmann decoder ($12.00)and set it for NO acceleration or Decelaeration and a start voltage of 0.
The function outputs on the decoder are open collector type, so a resistor, 1 k or so, needs to connected between the function positive common and the function outputs. The logic of selection will be inverted --function "ON" will result in a low output. The Bachmannn decoder only has a single function out put so I will have to purchase a four function decoder ($17.00) to meet my needs.
The good news is I can control the turntable with a DCC system; I just have stop adding features and finish the job!
David G.
Maryland, US
David G.
Maryland, US
PICAXE 28X2
'Note the pulse width readings are noisy and wander a bit so I use averaging to calm them down a bit.
'The use of Select Case command makes it easy to assign the correct number to the read pulse width.
'I tried using an optical coupler to connect to the DCC decoder but it did not lower the noise. I will look
'into the sourse of the noise --I have to borrow a friends O'scope.
symbol pulse = w0
symbol sum = w2
symbol average = b11
symbol number = b10
init:
high c.7 ' Be sure Tx Pin is idle for some time
Pause 1000 ' wait for LCD to boot
SerOut c.7, T9600, ("?f") ' clear the LCD and home the cursor
sum = 0 'clear sum
for average = 0 to 4 'set up for loop
pulsin c.0, 1, pulse 'read pulse width and put in "pulse"
sum = sum + pulse 'build up average
next
pulse = sum / 5 'calculate average
rem SerOut c.7, T9600, ("?f") I use this code to read what the pulse width is for each speed step.
rem SerOut c.7, T9600, ("pulse width ")
rem SerOut c.7, T9600, (#w0)
rem goto main
select case w0 'set up select casr for read pulse widths
case 0 to 39
'test for 0 -39 value of pulse width
number = 0 'if in this range set number to 0 and display result
SerOut c.7, T9600, ("?f") 'clear LCD and home cursor
SerOut c.7, T9600, ("Track Number ") 'display Track Number
SerOut c.7, T9600, ("N/A") 'display N/A --No Track 0!
case 40 to 65 'test for 40 -65 value of pulse width
number = 1:gosub lcd_out 'if in this range set number to 1 and display results
case 90 to 120
number = 2:gosub lcd_out 'Etc, etc....
case 145 to 169
number = 3:gosub lcd_out
case 195 to 220
number = 4:gosub lcd_out
case 250 to 279
number = 5:gosub lcd_out
case 320 to 360
number = 6:gosub lcd_out
case 400 to 440
number =7:gosub lcd_out
case 490 to 515
number =8:gosub lcd_out
case 560 to 590
number =9:gosub lcd_out
case 640 to 670
number =10:gosub lcd_out
case 740 to 780
number =11:gosub lcd_out
case 850 to 880
number =12:gosub lcd_out
case 950 to 980
number =13:gosub lcd_out
case 1050 to 1080
number =14:gosub lcd_out
case 1130 to 1200
number =15:gosub lcd_out
case 1290 to 1340
number =16:gosub lcd_out
case 1420 to 1440
number =17:gosub lcd_out
case 1550 to 1580
number =18:gosub lcd_out
case 1680 to 1720
number =19:gosub lcd_out
case 1800 to 1845
number =20:gosub lcd_out
case 1950 to 1999
number =21:gosub lcd_out
case 2120 to 2150
number =22:gosub lcd_out
case 2240 to 2285
number =23:gosub lcd_out
case 2410 to 2455
number=24:gosub lcd_out
case 2580 to 2630
number =25:gosub lcd_out
case 2670 to 2710
number =26:gosub lcd_out
case 3050 to 3090
number =27:gosub lcd_out
case 3300 to 3350
number =28:gosub lcd_out
ENDSELECT
goto main 'start over!
lcd_out:
SerOut c.7, T9600, (#number) 'display number value as a number
