Just a simple little project, born about due to no real temp control on my car AC. Using an 18x, DS18B20 and a 2x16 display. internal temp reading is taken 5 times and the average is used for display and control. This I may alter if it proves unsuitable. Picture of unit fitted into the car is not brilliant.
Usual caveats apply with my coding (I know it could be better..)
#picaxe18x
'CAR A/C TEMP CONTROL USING 18X AND DS18B20
'DISPLAYED ON 2X16 ALPHANUMERIC LCD
symbol lcd=2
symbol temp_sens=0
symbol backlight=3
symbol car_fan=pin1
symbol setpoint_dwn=pin2
symbol setpoint_up=pin7
symbol aircon=7
symbol setpoint=b13
symbol baud=t2400
symbol read_temp=w0
symbol counter=b6
symbol timer =b7
symbol control_temp=b0
symbol ave_temp=w2
symbol car_temp=w1
initialise:
pause 250 'lets start with a short delay shall we?
high lcd 'sets output high for serial display
pause 5 'just to make sure the output is high
serout lcd,baud,(254,1) 'clears the display
pause 500 'and waits for the display to settle
high backlight 'switch on lcd backlight
setpoint=20 'initial setpoint value
begin:
setint off
gosub display_clear
gosub release_setpoint_dwn_button'wait for button to be released
low aircon 'make sure aircon is off
serout lcd,baud,(254,128,"Kev's AC CONTROL")'here's the header
serout lcd,baud,(254,192," SYSTEM OFF ")'and here's the status
loop until setpoint_up=1 or setpoint_dwn=1'press any button to start
gosub release_setpoint_up_button'wait for button to be released
if car_fan=0 then 'if car fan isn't running then
serout lcd,baud,(254,192," TURN ON FAN ")'alert the driver
end if
if setpoint_dwn=1 then goto begin'turns system off after 2sec press
loop until car_fan=1 'and wait until it is!
serout lcd,baud,(254,192," SYSTEM ON ")'and now we start checking
'MAIN PROGRAM SUB-ROUTINE SEQUENCE
run:
setint %10000000,%10000000 'sets interrupt for temp adjustment
gosub temp_reading 'measure the cabin temp
gosub neg_check 'lets see if temp is negative
gosub control 'lets see if we need cooling shall we?
gosub display_values 'displays readings on lcd
goto run 'here we go again
'AVERAGE TEMP SAMPLING
temp_reading:
if setpoint_dwn=1 or car_fan=0 then goto begin'turns system off after 2sec press or car fan stopping
counter=0 'resets timer to zero and
ave_temp=0 'average temp to zero for next batch of readings
readtemp12 0,read_temp 'reads the in car temp
ave_temp=ave_temp+read_temp 'adds latest temp reading to average temp
pause 1000 '1 second delay before next reading
inc counter 'adds 1 to the timer
loop until counter=5 'this allows 5 readings to be taken
ave_temp=ave_temp/5 'this divides total value by 5 for average
'TEMP CALCULATION ROUTINE
neg_check:
car_temp=ave_temp 'load 'cartemp' into w1
bit15 = car_temp/32768 'isolate bit 15
if bit15 = 1 then 'check to see if bit 15 is 1
b8 = "-" 'character if temp is 'negative
car_temp=65535-car_temp+1 '2s compliment for negative temp
b8 = "."
end if
temp_calc:
car_temp=car_temp*10
w2=car_temp/16 'divide by 16
b0=w2/10 'divides by 10 and leave the 'whole' number
b1=w2//10 'divides by 10 and leave the remainder
'TEMP CONTROL ROUTINES
control:
if control_temp>setpoint then 'lets see if we need cooling
high aircon 'if so, turn on the aircon
b10="o"
b11="n"
b12=" "
else if control_temp<setpoint then 'and if not
low aircon 'turn off the aircon
b10="o"
b11="f"
b12="f"
end if
'DISPLAY AND INTERRUPT ROUTINES
display_values:
if b0<10 then
serout lcd,baud,(254,192,"Temp..",b8,#b0,".",#b1,223,"C ",b10,b11,b12)
serout lcd,baud,(254,192,"Temp.",b8,#b0,".",#b1,223,"C ",b10,b11,b12)
end if
display_clear:
serout lcd,baud,(254,192," ")
display_setpoint:
serout lcd,baud,(254,192,"S/P ADJUST..",#setpoint,223,"C")
interrupt:
gosub display_clear
gosub display_setpoint
for timer=0 to 250 'sets value for 'return'timer
pause 2
if setpoint_up=1 then inc_temp'jumps to 'inc_temp' or
if setpoint_dwn=1 then dec_temp'dec_temp' dependent on button push
next timer 'inc timer by 1
setint %10000000,%10000000 'resets the interrupt
timer=0 'makes sure timer is set to zero
inc_temp:
if setpoint>26 then let setpoint=15'resets setpoint to 15 if max 26 reached
end if
pause 3
inc setpoint 'adds one to the setpoint value
goto inc_temp 'loop if another increase is required
end if 'adds one to the setpoint
if setpoint_dwn=1 then dec_temp'jumps dependent on button push
dec_temp:
if setpoint<15 then let setpoint=26'resets setpoint to 26 if min 14 reached
end if
pause 3
if setpoint_dwn=1 then '
dec setpoint 'takes 1 away from the setpoint value
goto dec_temp 'loop if another decrease is required
end if 'takes 1 away from the setpoint
if setpoint_up=1 then inc_temp'jumps dependent on button push
release_setpoint_up_button:
loop until setpoint_up=0 'wait for button to be released
pause 10 'pause just to make sure
release_setpoint_dwn_button:
loop until setpoint_dwn=0 'wait for button to be released
