​ ​ ​ ​ car AC thermostat
Page 1 of 2 1 2 LastLast
Results 1 to 10 of 11
Thread: car AC thermostat
  1. #1
    Join Date
    Jan 1970
    Location
    UK, Bristol
    Posts
    462
    Default car AC thermostat
    Just a simple little project, born about due to no real temp control on my car AC. Using an 18x, DS18B20 and a 2x16 display. internal temp reading is taken 5 times and the average is used for display and control. This I may alter if it proves unsuitable. Picture of unit fitted into the car is not brilliant.
    Usual caveats apply with my coding (I know it could be better..)
    					#picaxe18x
    				'CAR A/C TEMP CONTROL USING 18X AND DS18B20
    				    'DISPLAYED ON 2X16 ALPHANUMERIC LCD
    symbol lcd=2
    symbol temp_sens=0
    symbol backlight=3
    symbol car_fan=pin1
    symbol setpoint_dwn=pin2
    symbol setpoint_up=pin7
    symbol aircon=7
    symbol setpoint=b13
    symbol baud=t2400
    symbol read_temp=w0
    symbol counter=b6
    symbol timer =b7
    symbol control_temp=b0
    symbol ave_temp=w2
    symbol car_temp=w1
    initialise:
    pause 250				'lets start with a short delay shall we?
    high lcd				'sets output high for serial display
    pause 5				'just to make sure the output is high
    serout lcd,baud,(254,1)		'clears the display
    pause 500				'and waits for the display to settle
    high backlight			'switch on lcd backlight
    setpoint=20				'initial setpoint value
    begin:
    setint off
    gosub display_clear
    gosub release_setpoint_dwn_button'wait for button to be released
    low aircon				'make sure aircon is off
    serout lcd,baud,(254,128,"Kev's AC CONTROL")'here's the header
    serout lcd,baud,(254,192,"   SYSTEM OFF   ")'and here's the status
    loop until setpoint_up=1 or setpoint_dwn=1'press any button to start
    gosub release_setpoint_up_button'wait for button to be released
    if car_fan=0 then			'if car fan isn't running then
    serout lcd,baud,(254,192,"  TURN ON FAN   ")'alert the driver
    end if
    if setpoint_dwn=1 then goto begin'turns system off after 2sec press
    loop until car_fan=1		'and wait until it is!
    serout lcd,baud,(254,192,"   SYSTEM ON    ")'and now we start checking
    				'MAIN PROGRAM SUB-ROUTINE SEQUENCE
    run:
    setint %10000000,%10000000	'sets interrupt for temp adjustment
    gosub temp_reading		'measure the cabin temp
    gosub neg_check			'lets see if temp is negative
    gosub control			'lets see if we need cooling shall we?
    gosub display_values		'displays readings on lcd
    goto run				'here we go again
    				'AVERAGE TEMP SAMPLING
    temp_reading:
    if setpoint_dwn=1 or car_fan=0 then goto begin'turns system off after 2sec press or car fan stopping
    counter=0				'resets timer to zero and
    ave_temp=0				'average temp to zero for next batch of readings
    readtemp12 0,read_temp		'reads the in car temp
    ave_temp=ave_temp+read_temp	'adds latest temp reading to average temp
    pause 1000				'1 second delay before next reading
    inc counter				'adds 1 to the timer
    loop until counter=5		'this allows 5 readings to be taken
    ave_temp=ave_temp/5		'this divides total value by 5 for average
    				'TEMP CALCULATION ROUTINE
    neg_check:
    car_temp=ave_temp			'load 'cartemp' into w1
    bit15 = car_temp/32768		'isolate bit 15
    if bit15 = 1 then			'check to see if bit 15 is 1
    b8 = "-"				'character if temp is 'negative
    car_temp=65535-car_temp+1	'2s compliment for negative temp
    b8 = "."
    end if
    temp_calc:
    car_temp=car_temp*10
    w2=car_temp/16				'divide by 16
    b0=w2/10				'divides by 10 and leave the 'whole' number
    b1=w2//10				'divides by 10 and leave the remainder
    				'TEMP CONTROL ROUTINES
    control:
    if control_temp>setpoint then 'lets see if we need cooling
    high aircon				'if so, turn on the aircon
    b10="o"
    b11="n"
    b12=" "
    else if control_temp<setpoint then 'and if not
    low aircon				'turn off the aircon
    b10="o"
    b11="f"
    b12="f"
    end if
    				'DISPLAY AND INTERRUPT ROUTINES
    display_values:
    if b0<10 then
    serout lcd,baud,(254,192,"Temp..",b8,#b0,".",#b1,223,"C ",b10,b11,b12)
    serout lcd,baud,(254,192,"Temp.",b8,#b0,".",#b1,223,"C ",b10,b11,b12)
    end if
    display_clear:
    serout lcd,baud,(254,192,"                   ")
    display_setpoint:
    serout lcd,baud,(254,192,"S/P ADJUST..",#setpoint,223,"C")
    interrupt:
    gosub display_clear
    gosub display_setpoint
    for timer=0 to 250		'sets value for 'return'timer
    pause 2
    if setpoint_up=1 then inc_temp'jumps to 'inc_temp' or
    if setpoint_dwn=1 then dec_temp'dec_temp' dependent on button push
    next timer				'inc timer by 1
    setint %10000000,%10000000	'resets the interrupt
    timer=0				'makes sure timer is set to zero
    inc_temp:
    if setpoint>26 then let setpoint=15'resets setpoint to 15 if max 26 reached
    end if
    pause 3
    inc setpoint			'adds one to the setpoint value
    goto inc_temp			'loop if another increase is required
    end if				'adds one to the setpoint
    if setpoint_dwn=1 then dec_temp'jumps dependent on button push
    dec_temp:
    if setpoint<15 then let setpoint=26'resets setpoint to 26 if min 14 reached
    end if
    pause 3
    if setpoint_dwn=1 then '
    dec setpoint			'takes 1 away from the setpoint value
    goto dec_temp			'loop if another decrease is required
    end if				'takes 1 away from the setpoint
    if setpoint_up=1 then inc_temp'jumps dependent on button push
    release_setpoint_up_button:
    loop until setpoint_up=0	'wait for button to be released
    pause 10				'pause just to make sure
    release_setpoint_dwn_button:
    loop until setpoint_dwn=0	'wait for button to be released
    Attached Images Attached Images
  2. #2
    Default
    Nice display!
    As this is one of those 'controversial' CAR applications, it would be nice to see the circuit you used to tame the 12v and protect the PICAXE from the car electrics.
  3. #3
    Join Date
    Jan 1970
    Location
    UK, Bristol
    Posts
    462
    Default
    As I used a PCB design from a previous project, I didn't take any real special precautions as such, my thinking was that if there is a problem, then I could just add a 'supply conditioning' board prior to connecting the picaxe board.
    There is a MOS varistor on board across the supply terminals (wrong symbol on the diagram but the closest I had).
    I have the usual diode across the relay coil, and a 4.7uf tantalum close to the 18x supply pins.
    It's been working ok for two days now without a glitch so hopefully all is well.
    I will add that this isn't necessarily the correct way of doing things, just the approach that I took in this instance.
  4. #4
    Default
    At least you've got a fuse, more than most remember to put in.
    The varistor might like to be the other side of it though.
  5. #5
    Thumbs up
    Nice Finish; board and display.
    Good choice of LCD, easy to read.
    And should keep the crowds happy..... not mission critical in a car
    01 start:
    02 goto start ' will I ever reach the end
    03 end
  6. #6
    Join Date
    Jun 2008
    Location
    Posts
    1,110
    Thumbs up
    The display is really nice looking!!
    Where did you get the LCD and the LCD Bezel? They look very professional!
    Averaging several readings is a good practice to filter noise. And since the temperature changes quite slowly, a delay of a few milliseconds has no ill effect.
  7. #7
    Join Date
    Jan 1970
    Location
    UK, Bristol
    Posts
    462
    Default
    Peter M, fernando_g, thanks for the comments...the the bezel came from MMS Electronics...not that cheap but makes finishing off a bit easier,
    and the display is white characters on a dark background, and is an e-bay listing...
    item no. 190323666195
    There are a large number of colours in the 16x2. I did get also red one and a blue one, both look quite nice but would be more difficult to read in bright light. Its tempting to stock up with the other colours for the future
  8. #8
    Join Date
    Oct 2008
    Location
    Australia
    Posts
    3
    Default
    Kevrus,
    You've inspired me! I'm only new to PICAXE but I thought I'd have a go at this project to learn more about them and to keep from freezing in my toyota Hilux.
    I have ordered one of the LCD displays from ebay and after reading the specifications I beleive it to be a parallel input. Is this correct or can you set it to be a serial input?
    Cheers,
    Mick
  9. #9
    Join Date
    Jan 1970
    Location
    UK
    Posts
    24,220
    Default
    Quote Originally Posted by mudgee73 View Post
    No idea without knowing exactly what you bought but most LCD said to be for parallel input are only for parallel input. Details should be in its datasheet. You need to add a FRM010 or use another PICAXE to turn it into a serially controlled module.
  10. #10
    Default
    Ditto.
    Surely the Ebay vendor showed a Data Sheet which could answer your question?
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
