​ ​ ​ ​ servo noise problems
Page 1 of 2 1 2 LastLast
Results 1 to 10 of 20
Thread: servo noise problems
  1. #1
    Join Date
    Jun 2009
    Location
    UK
    Posts
    10
    Default servo noise problems
    Hi
    I've published a camera panorama robot rig at:
    http://www.instructables.com/id/Came...ead-panograph/
    This has two servo's controlled by the AXE024 servo board. I have some timing issues that I need to resolve.
    The servo board literature states that servo noise could cause erratic behaviour & I'm seeing that.
    In my code I'm moving the camera to 30 discrete locations, 5 in the x axis & 4 in the y axes. two servo motors position the camera. In my code, I was hoping to put a pause in before giving the instruction to fire the camera shutter (pause to allow the camera to steady after moving). So, if I place the pause before firing the shutter, the circuit behaves erratically. The first shutter does not fire, then subsequently the shutter fires immediatley after a move. It seems to me that the servo's operating affect the internal clocking of he picaxe?
    I understand the AXE024 has certain ways to reduce noise: diode protecting the picaxe from supply line with servo's. Two tant caps to reduce the effect of servo loading. decoupling caps (100nF) on supply line to picaxe & across supply pins of servo's. I have added some ferrite coils to reduce HF noise also.
    Any help or thoughts appreciated. I've enclosed my code below:
    symbol servo_delay = 60 'recommended delay between servo movements
    symbol top = 160 'max y position
    symbol bottom =220 'min y position
    symbol left = 180 'min x position
    symbol right = 100 'max x position
    symbol vstep = 20 'vertical increments
    symbol hstep = 20 'horizontal increments
    symbol pic_delay = 100
    symbol camera_steady_delay = 4000 'delay to steady camera after movement
    GOSUB Init
    for b2 = top to bottom step vstep
    for b1 = right to left step hstep
    servo 1,b1
    pause servo_delay
    GOSUB take_picture
    pause camera_steady_delay
    next b1
    servo 2,b2
    pause servo_delay
    next b2
    end
    take_picture:
    high 4
    pause 30
    low 4
    Init:
    servo 2,top
    low 4
  2. #2
    Default
    The code as you currently have it waits for 60mS after the servo command, then takes a picture, then waits for 4 seconds before moving off again.
    If you swap over the two lines (which I think is what you wanted)
    GOSUB take_picture
    what actually (in detail) goes wrong?
    It sounds like you have all the obvious things to suppress any electrical noise and there does not appear to be any eveidence of the PICAXE resetting so I'm not too sure what your actual problem is. More detail please. Can you describe "erratic" more precisely.
    The code you have posted WILL behave the way you explain.
    Please post the code which you WANT but does not work as expected.
  3. #3
    Join Date
    Jun 2009
    Location
    UK
    Posts
    10
    Default
    With the code I have supplied, the camera fires pretty much immediately after the camera has moved, then a pause before moving and firing again. At lease the camera fires after each move.
    If, as I would like, I swap the two lines round to
    GOSUB take_picture
    the camera doesn't fire in the first position, camera moves, camera fires less than a second after the move.
    By erratic, I think I mean doesn't work as expected from the code
    I'd expect:
    Initialise
    pause
    camera fire
    move camera
    That 4 second pause seems to happen
  4. #4
    Default
    To me, "erratic" means 'differently every time.
    Does your code (the way you want it) do the same thing everytime?
    Does it miss the first trigger EVERY time?
    Is the 4 second delay short EVERY time?
    Is it short by the same amount everytime or does it appear random?
  5. #5
    Join Date
    Jun 2009
    Location
    UK
    Posts
    10
    Default
    Quote Originally Posted by BeanieBots View Post
    Sorry, been a long day. Better to say that it works unexpectedly, but the same every time
    Does your code (the way you want it) do the same thing everytime? yes
    Does it miss the first trigger EVERY time? yes
    Is the 4 second delay short EVERY time? yes
    Is it short by the same amount everytime or does it appear random? same every time < 1 second
    In fact I've measured the total delay between camera movements, ignoring camera shutter & it's about 4 seconds.
    In the last position two shots are fired
  6. #6
    Default
    Your answers make me think that nothing is wrong and you do not suffer noise issues.
    I think it is your code and/or hardware logic.
    Might be a good idea to post your circuit.
    For the missed first picture, this could be your logic.
    What happens if you change the take_picture to:-
    take_picture:
    low 4
    pause 30
    high 4
    return (EDIT: also change init: to HIGH 4)
    As for the short pause, I've not experienced any problems mixing pauses with servo commands so I don't think there is an issue and if it was noise related, I would expect ERRATIC behaviour. Your circuit is behaving very consistantly.
    This VERY STRONGLY suggets code or hardware DESIGN error.
    It might even still boil down to inverted logic which the above test (or your circuit) will disclose. However, don't forget that the servo takes time to travel. The command does not wait until it's finished moving. It tells the servo where to go and then processes the next command while the servo moves.
  7. #7
    Default
    It takes time for the servo to move from A to B. Longer than 60mS! The SERVO command is NOT a blocking command. That is, there is no pause or delay in the program when the command is issued. And once the command is issued it will continue moving, even during a WAIT or PAUSE, until it reaches its destination.
    You want something like this:
    ‘PSEUDO CODE
       Issue one servo command to start the movement
       Wait sufficient time for the servo to reach its destination position and stop (and settle)
       Take photo
    Loop
    I would experiment with the ‘waiting for servo to arrive and settle’ delay to find the optimum, but start at around 800mS and reduce it bit by bit until you start to see camera shake on the pictures*, then increase it back up a little (say +200mS to give yourself a small margin).
    (*Because the shutter opens before the servo has settled)
    There may also be a camera lag as it focuses, calculates exposure etc, which can also be accounted for in the same ‘wait for servo’ delay.
    War is Peace. Freedom is Slavery. Ignorance is Strength.
  8. #8
    Default
    Oh yes. One more thing....
    I have found by experimentation that servos can get a little jittery/shaky/twitchy because of noise on the signal line (Picaxe SERVO pin). I have also found that setting that output to LOW can stop it. Experiment
  9. #9
    Join Date
    Jun 2009
    Location
    UK
    Posts
    10
    Default
    Thanks both, I hadn't considered the servo move time whilst the program continuing during movement. Also I'll try inverting the take_picture pulse too.
    Thanks also for the servo 'twitching' comment. I had noticed one of the servo's doing that occasionally. I'll try your suggestion.
    I don't have a circuit drawn yet. Broadly, its a picaxe servo controller board with two of the servo's outputs connected (x and y axes movement servo's) The third pcb servo output I've wired using a mini usb cable which is plugged into my Canon G9 (+'ve to signal pin , black to ground) Canon G9 is loaded with CHDK alternative firmware (SDM variant).I'll post a diagram when I get access to VISIO.
    ps I can't try these out till Thursday, but some good things to try then. I'm also glad to hear BeanieBots has had success with servo's & pauses, encourages me
  10. #10
    Default
    Apologies. I made a mistake (Senior moment). You need to set the pin HIGH to prevent servo-twitch, not LOW.
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
