LS-41EB-3V GPS Module Tutorial
radcom
Where can I find the tutorial for the LS-41EB-3V GPS Module as the only links I have found are broken links
edit: the file name should be: axe210_GPS.pdf
thanks
MPep
The problem has been that if an instruction manual is made for 1 particular GPS, it may not apply to others. I believe it was decided quite some time ago not to proceed, at least not from RevEd.
The challenge was open for any contributor to write one if they so wished. But again, where do you start?
Feel free to ask questions as quite a few of us have prior knowledge of working with various GPS modules.
Was there anything specific you needed to know?
Start with the one being used. If each member wrote up a section about comms, codes, etc and PICAXE program related to the GPS they are working and it was all posted into the same (say) code snippets thread then a reasonal "tutorial" would gradually be built up.
