​ ​ ​ ​ LS-41EB-3V GPS Module Tutorial
Results 1 to 4 of 4
Thread: LS-41EB-3V GPS Module Tutorial
  1. #1
    Join Date
    Jan 1970
    Location
    Sheffield
    Posts
    50
    Default LS-41EB-3V GPS Module Tutorial
    Where can I find the tutorial for the LS-41EB-3V GPS Module as the only links I have found are broken links
    edit: the file name should be: axe210_GPS.pdf
    thanks
  2. #2
    Join Date
    Mar 2008
    Location
    Western Australia
    Posts
    12,245
    Default
    this link from the datasheet page is working to the AXE210:
    http://www.rev-ed.co.uk/docs/axe210.pdf
    for the GS these links are working:
    http://www.rev-ed.co.uk/docs/GPS001.pdf
    http://www.rev-ed.co.uk/docs/GPS001A.pdf
    But yes the "AXE210_GPS.pdf" GPS specific tutorial mentioned in several places does not exist - even trying other search methods.
    hippy could not find it over 2.4 years ago . . . . so not a new item/problem
    http://195.74.60.76/showthread.php?t=5806
    Hey Hamlet, 2B OR NOT 2B = $FF
  3. #3
    Join Date
    Jan 1970
    Location
    Rangiora, New Zealand
    Posts
    1,531
    Default
    The problem has been that if an instruction manual is made for 1 particular GPS, it may not apply to others. I believe it was decided quite some time ago not to proceed, at least not from RevEd.
    The challenge was open for any contributor to write one if they so wished. But again, where do you start?
    Feel free to ask questions as quite a few of us have prior knowledge of working with various GPS modules.
    Was there anything specific you needed to know?
    In theory, there is no difference between theory and practice. In practice, there is...
  4. #4
    Join Date
    Mar 2008
    Location
    Western Australia
    Posts
    12,245
    Thumbs up
    Quote Originally Posted by MPep View Post
    Start with the one being used. If each member wrote up a section about comms, codes, etc and PICAXE program related to the GPS they are working and it was all posted into the same (say) code snippets thread then a reasonal "tutorial" would gradually be built up.
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
