Dear All:
I’m try to do a serial-keypad experiment using PICAXE 18X and a keypad, I need to capture and put into PICAXE one external variable introduced by the keypad and sent to other PICAXE with SEROUT command, but it woks in the simulator, but when I try to use it in the protoboard it doesn’t work, I check and re-check all connection and everything is OK, may the code has an error could someone help me to check the code please
Thanks
ARMAGON29
Thanks
ARMAGON29
