John Gracey
Im trying to get my math co-processor to work. It is the Um-fpu V3.1 dip chip. I am trying to use it with an i2c bus setup, but unfortunatly the chip dosnt respond. I followed the data sheet and tied all the pins high, ground, and used the usual 4k7 resistors to tie the i2c bus lines high. I also used the um-fpu picaxe source code and the template. I am using a 5v regulated power source from a 12 volt lead acid battery. I download my program to my picaxe 18x, to find the terminal readings (via sertxd comand) announce that the um-fpu chip is not detected. I dont believe static is a problem. Anyway can anyone help me out? Thanks a hole bunch
