installation error
aberdeenjetman
when i try to install bas805.exe i get the following error:
Error reading setup initalization file
i am running XP home
please help
james
This error normally occurs when the downloaded file is put in a folder with other installation files (from other software installations) in it, confusing the installer service (e.g. on the desktop).
Try putting the file bas805.exe downloaded into a new, empty folder and run from there.
4wd
I have tried the fix suggested but I also get the 'Error reading Setup initialization file' whenever I try to run the install file.
Have downloaded the file multiple times but no difference.
Have tried compatibilty settings but no joy, (I'm running WinXP SP1).
Anyone have any other ideas?
4wd
Since nothing has helped with not getting this error and no-one has suggested anything that works: Does anyone have an earlier version, (3.4.0), that I can try to install and then upgrade?
Thanks.
All versions are created using the same version of InstallShield so this would not make any difference.
